Slot/Card Installation
Slot Configuration
Slot | Usage |
Slot 1 Gen5 x16 | Second Graphics Card |
Slot 2 empty | |
Slot 3 Gen5 x8 | Nvidia Sync Board |
Slot 4 Gen5 x16 | Matrox M264 |
Slot 5 Gen5 x4 | |
CPU and Memory | |
Slot 6 Gen5 x16 | First Graphics Card |
Slot 7 Gen5 x8 | |
Slot 8 Gen5 x8 | |
Slot 9 Gen5 x16 | Matrox Video Card (X.mio5, DSX LE5) |
Slot 10 Gen4 x4 | |
Default Hardware
Single CPU 20-Cores
Dual Redundant Power Supply: 1350W @110V or 1700W @200V, Platinum Rated (92% Efficient)
PCIe Gen4+Gen5 Slots
9 PCIe Slots
128GB DDR5 2x 1TB M.2
1x Gbit RJ45 onboard
2x 10Gbit RJ45 Flex IO
OS Support:
Windows 11 LTSC 2024
GPU Support:
Nvidia Blackwell: RTX PRO 2000 Blackwell, RTX PRO 4000 Blackwell, RTX PRO 5000 Blackwell, RTX PRO 6000 Blackwell Max-Q (300W)
Matrox Support: XMIO5, DSXLE5, M264, DSXLE6D100
Bios Settings
Security/Secure Boot Configuration Secure Boot: Enable
Advanced/System Options
USB Type-C Connector System Software Interface (UCSI): Disable
Advanced/Built-In Device Options:
Increase PCIe Idle Fan Speed(%): 30
PCIe Idle Fan Tracking mode: Enable
Advanced/Power Management Options:
Hardware P-States: Disable
Runtime Power Management: Disable
BIOS Energy/Performance Bias: Performance
S4/S5 Maximum Power Savings: Disable
PCI Express Power Management: Disable
Advanced/Performance Options:
Performance Control: Ultimate Performance Mode
Workload Configuration: I/O-Focused
Advanced/Power Supply Options:
Power Supply Mode: Redundant
