This section describes how to setup a Lenovo P620 machine with the different cards provided by Vizrt. The Lenovo P620 is a high performance workstation that can be configured with two CPUs, has eight memory slots, multiple storage and PCIe configuration options.
More details about the Lenovo P620 can be found on Lenovo’s website: Lenovo P620.
Info: Only newer Matrox Boards like X.mio3 and DSX LE4 are shipped with P620 workstations. Older videoboards are not tested by Vizrt.
PCI Configuration for Single GPU
Slot
Usage
Slot 1 – PCIe4 x16
Matrox AES Audio
G-Sync III
Blue Storm
Sea Level
Single Port Network Card
Slot 2 – PCIe4 x8
Empty
Slot 3 – PCIe4 x16
Graphics Card (Single / Dual Slot)
Slot 4 – PCIe4 x16
Used if Dual Slot GPU is installed
Slot 5 – PCIe4 x16
If one Graphic Card is installed, this slot is used for Video Cards (Matrox Video Boards)
Slot 6 – PCIe4 x8
Empty or can be used by Matrox AES Audio if Slot 1 is used
PCI Configuration for Single GPU with M264
Slot
Usage
Slot 1 – PCIe4 x16
M264
Slot 2 – PCIe4 x8
Matrox AES Audio
Blue Storm
Sea Level
Slot 3 – PCIe4 x16
Primary Graphics Card (Single / Dual Slot)
Slot 4 – PCIe4 x16
Primary Graphics Card (Dual Slot)
Slot 5 – PCIe4 x16
Video Card (Matrox)
Slot 6 – PCIe4 x8
Quadro Sync
PCI Configuration for Dual GPU
Slot
Usage
Slot 1 – PCIe4 x16
Slot 2 – PCIe4 x8
Slot 3 – PCIe4 x16
Video Card (Matrox)
Slot 4 – PCIe4 x16
Matrox AES Audio
G-Sync III
Blue Storm
Sea Level
Slot 5 – PCIe4 x16
Secondary Graphics Card (Single / Dual Slot)
Slot 6 – PCIe4 x8
Secondary Graphics Card (Dual Slot)
Default Hardware
  • Tower 4RU
  • CPU: AMD Threadripper Pro 3955WX (16-Core, 3.90GHz, 8MB) or 5955WX (16-Core, 4.00GHz, 8MB)
  • RAM: 64 GB DDR 4 (4x 16GB)
  • SSD1: 512 GB M.2 NVMe (Operating System)
  • SSD2: 512 GB M.2 NVMe (Data and Clips)
  • Power Supply: 1x 1000W Power Supply
  • OS Support:
    • Windows 10 LTSC 2021
    • Windows 11 LTSC 2024
  • GPU Support:
    • ​Nvidia Ampere: RTX A2000, RTX A4000, RTX A5000, RTX A6000
    • Nvidia Ada: RTX 2000 Ada, RTX 4000 Ada, RTX 5000 Ada, ​RTX 6000 Ada
  • Matrox Support: XMIO3, XMIO5, DSXLE4, DSXLE5, M264
Info: Certain third party vendor drivers require secure boot to be disabled to install properly.
