Slot/Card Installation
Slot Configuration
Slot
Usage
Slot 1 Gen5 x16
First Graphics Card
Slot 2 Gen5 x4
Free or used by Dual Slot GPU
CPU and Memory
Slot 3 Gen5 x16
Second Graphics Card or Matrox M264
Slot 4 Gen4 x4
Other Expansion Card (Serial, GPI)
Slot 5 Gen5 x16
Matrox Video Card (X.mio3, X.mio5, DSX LE4)
Slot 6 empty
Default Hardware
  • Single CPU 12-Cores
  • ​Power Supply: 1350W @110V or 1700W @200V, Platinum Rated (92% Efficient)
  • ​PCIe Gen4+Gen5 Slots
  • ​5 PCIe Slots
  • ​64GB DDR5 ​2x 1TB M.2 ​
  • 1x Gbit RJ45 onboard ​
  • 2x 10Gbit RJ45 Flex IO
  • OS Support:
    • Windows 11 LTSC 2024
  • GPU Support:
    • Nvidia Blackwell: RTX PRO 2000 Blackwell, RTX PRO 4000 Blackwell, RTX PRO 5000 Blackwell, RTX PRO 6000 Blackwell Max-Q (300W)
  • Matrox Support: XMIO5, DSXLE5, M264
Bios Settings
  • Security/Secure Boot Configuration Secure Boot: Enable
  • Advanced/Built-In Device Options:
    • Increase PCIe Idle Fan Speed(%): 30
  • Advanced/Power Management Options:
    • Hardware P-States: Disable
    • S4/S5 Maximum Power Savings: Disable
    • PCI Express Power Management: Disable
  • Advanced/Performance Options:
    • Workload Configuration: I/O-Focused
