Supported Software
Viz Engine Software
To run Viz Engine as a program or preview (optional) machine, the following software and configuration is needed:
Viz Engine specifications
Category |
Requirement |
Software |
Codemeter runtime for WIBU based licensing |
Hardware |
License dongle for legacy hardlock licensing or valid Codemeter license |
Executable(s) |
viz.exe |
Ports and Connections |
Network access |
Preview Server
The Preview Server option is used in situations where Viz Engine is used to provide frames for snapshot or thumbnail generation. A typical use case would be to connect multiple Newsroom Components to a preview server.
The Preview Server must be installed on a separate Viz Engine machine with its own license.
Category |
Requirement |
Software |
Hardware |
License dongle for legacy hardlock licensing or Codemeter license |
Executable(s) |
PreviewServer.exe |
54000: Used to connect over HTTP with the REST interface. |
Network access |
Uses the ZeroConf protocol to announce available services. |
Viz Artist Software
The Viz Artist design machine should preferably have the same specifications as the Viz Engine playout renderer, especially if the designers need to test performance issues on demanding scenes.
If designers are creating templates for Viz Pilot, it is recommended that Viz Pilot is installed on a separate machine for more accurate playout emulation on Viz Engine.
