BlueFish444 Epoch 2K Horizon
The BlueFish444 Epoch 2K Horizon board is intended for character generators such as Viz Trio, but can also be used as an alternative where only two inputs and outputs are required. The boards are typically installed on HP Z800 machines.
Configuration History
Use the driver version available on Vizrt’s FTP server to make sure of correct functionality and ringbuffer support.
3.6.3, driver version Bluefish444 v5.10.2.18
3.6.1 - 3.6.2, driver version Bluefish444 v5.10.2.4
3.5.1 - 3.5.4, driver version Bluefish444 v5.10.1.11
3.5.0, driver version Bluefish444 v5.9.0.78
