Pinnacle Targa 3200
Pinnacle Targa 3200 was Vizrt’s standard card for SD Viz systems until 2007, and was typically used with IBM ZPro 6221, IBM Z-Pro 6223 and HP xw8200.
Configuration History
Driver |
Revision |
CODI v2.42 |
3213. Revision 3213 crashes the machine when used with CODI v2.41rc13. |
CODI v2.41rc13 |
3212, 3214. Installation of CODI Compatibility Patch for revision 3214 is no more required. |
CODI v2.42 |
3212, 3213, 3214. Installation of CODI Compatibility Patch is required. |
CODI v2.2 RC4 |
3212, 3213 |
