Viz Engine
Video Output: SHM Output
Configure Shared Memory Output channels from this panel. The shared memory output is only available on systems with non-IP Matrox video boards, or if Check Video Card is set to None in the Video Board section.
Shared Memory Output: Set the output mode for Shared Memory. Options are Active or Inactive.
Color Format: Displays the active color format for the configured SHM Output.
Unique Identifier: Changes the name of the Shared Memory if required. Used when connecting to services such as Viz Coder.
