Viz Engine
NVIDIA Legacy Cards
This section details all legacy NVIDIA cards:
NVIDIA Quadro 6000
Windows XP / Windows 7 (64bit)
Viz Artist/Engine Version |
Driver |
3.5.4 |
311.50 |
3.5.2 - 3.5.3 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
The card supports:
SDI output with Matrox X.mio2
SDI capture with NVIDIA Quadro SDI Output card
G-SYNC II
NVIDIA Quadro 5000
Driver |
3.5.4 |
311.50 |
3.5.2 - 3.5.3 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
The card supports:
G-SYNC II
NVIDIA Quadro 4000
Driver |
3.5.4 |
311.50 |
3.5.2 - 3.5.3 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
NVIDIA Quadro 2000
Driver |
3.5.4 |
311.50 |
3.5.2 - 3.5.3 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
NVIDIA Quadro FX 1400
Windows XP
Driver |
3.5.2 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
3.0 |
81.67 |
NVIDIA Quadro FX 1500
Windows XP
Driver |
3.5.2 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
3.0 |
162.62 |
NVIDIA Quadro FX 1700
Windows XP
Driver |
3.5.4 |
311.50 |
3.5.2 - 3.5.3 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
3.0 |
162.62 |
NVIDIA Quadro FX 1800
Windows XP
Driver |
3.5.4 |
311.50 |
3.5.2 - 3.5.3 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
NVIDIA Quadro FX 3400
Windows XP
Driver |
3.5.2 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
3.0 |
81.67 |
NVIDIA Quadro FX 3450
Windows XP
Driver |
3.5.2 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
NVIDIA Quadro FX 3500
Windows XP
Driver |
3.5.2 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
3.0 |
81.67 |
NVIDIA Quadro FX 3700
Windows XP
Driver |
3.5.4 |
311.50 |
3.5.2 - 3.5.3 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
3.0 |
162.62 |
NVIDIA Quadro FX 3800
Windows XP
Driver |
3.5.4 |
311.50 |
3.5.2 - 3.5.3 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
NVIDIA Quadro FX 4400
Windows XP
Driver |
3.5.2 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
NVIDIA Quadro FX 4500
Windows XP
Driver |
3.5.2 - 3.5.3 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
3.0 |
83.62 |
The card supports:
G-SYNC II
NVIDIA Quadro FX 4600
Windows XP
Driver |
3.5.4 |
311.50 |
3.5.2 - 3.5.3 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
3.0 |
162.62 |
The card supports:
NVIDIA Quadro FX 4800
Windows XP
Driver |
3.5.4 |
311.50 |
3.5.2 - 3.5.3 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
The card supports:
G-SYNC II
NVIDIA Quadro FX 5500
Windows XP
Driver |
3.5.2 |
296.70 |
3.1.0 - 3.5.1 |
275.36 (or 91.36 when used with Video Wall (SDI only)) |
3.0 |
162.62 |
The card supports:
G-SYNC II
If you experience driver problems, set use_old_nvsdk to 1 in the Viz Config file.
NVIDIA Quadro FX 5600
Windows XP
Driver |
3.5.4 |
311.50 |
3.5.2 - 3.5.3 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
3.0 |
162.62 |
The card supports:
NVIDIA Quadro FX 5800
Windows XP
Driver |
3.5.4 |
311.50 |
3.5.2 - 3.5.3 |
296.70 |
3.1.0 - 3.5.1 |
275.36 |
The card supports:
G-SYNC II
NVIDIA Quadro K600
Windows 7 (64bit) / Windows Server 2008 R2/SP1 (64bit)
Driver |
3.6.4 |
341.21 |
