Viz Engine
HP DL360 Gen9
The HP DL360 Gen9 is a space-saving 1U server. This is a dual-CPU server with 24 DIMM slots, which is configured with Windows Server 2008 R2.
Only single slot NVIDIA Graphics Cards can be used, either M2000 or M4000.
There are two expansion slots:
One for the Graphic Card.
One for a Matrox X.mio3 or DSX LE 4 video card.
The HP DL360 Gen9 with Quadro K4200 and DSXLE3 video I/O:
HP DL360 Gen9 BIOS settings
Setting |
Value |
System Options > Processor Options -> Hyperthreading |
Disabled |
Performance Options -> Node Interleaving |
Enabled |
Performance Options -> QPI Snoop Configuration |
Home Snoop |
Advanced Options -> Video Options -> Add-in Video |
Enabled |
Advanced Options -> Video Options -> Embedded Video |
Disabled |
Power Management -> Power Profile |
Maximum Performance |
Boot Options -> UEFI Optimized Boot: |
For systems running Windows Server 2008 R2 |
Disabled |
For systems running Windows Server 2012 R2 |
Enabled |
