Viz Engine
Dell R7920
Dell R7920 Rack Workstation slots
Slot |
Usage |
Slot 1 – PCIe3 x8 |
Graphics Card only! (Single / Dual Slot) |
Slot 2 – PCIe3 x8 |
Used if a Dual-Slot Graphics Card is installed |
Slot 3 – PCIe3 x8 |
Video Card (i.e. Matrox Video Board) |
Slot 4 – PCIe3 x16 |
Expansion Cards: Matrox AES Audio |
Slot 5 – PCIe3 x8 |
Video Card (i.e. Matrox Video Board) (if two Graphics Cards are installed) |
Slot 6 – PCIe3 M2 SSD |
PCIe M.2 SSD |
Slot 7 – PCIe3 x8 |
Slot 7 – PCIe3 x8 |
Second Graphics Card |
Note: Only Matrox boards have been tested.
BIOS settings
During Post, press F2 to get access to the BIOS Setup
Click on “System BIOS”
Click on “Processor Settings”
Set Logical Processor to “DISABLED”
Press ESC to Exit Menu
Click on SATA Settings
Set “Embedded SATA” to “RAID MODE”
Click on NVMe Settings
Set “NVMe Mode” to “NonRAID”
Click on Boot Settings
Check if “Boot Mode” set to “UEFI”
Click on Integrated Devices
Set “Embedded Video Controller” to “DISABLED”
Click on System Profile Settings
Set System Profile to “Performance”
Press ESC twice, Settings will be saved
Exit Bios
Press F2 to access BIOS
Change Boot Order (C should be at top)
Save Changes and Exit
Only newer Matrox Boards like xMio3 and DSX.LE are shipped with Dell R7920 workstations. Older videoboards are not tested by Vizrt.
Certain third party vendor drivers require secure boot to be disabled to install properly.
