Viz Engine
Mixed Mode Video Support
This section gives an overview of the Matrox’ mixed mode video support. The tables are valid for both genlock families in Viz Engine. One is 25/50 (e.g. PAL/720p50/1080i25/1080i50) and the other is 30M/60M (e.g. NTSC/720p60M/1080i30M/1080i60M).
The genlock family refers to the used house signal (e.g. black burst) frequency - typically PAL for the first and NTSC for the latter. Please observe that genlock families can not be mixed.
The following contain information on the following topics:
Source: PAL or NTSC
The first two tables show video in to DVE and texture output capabilities, while the next two tables show clip in to DVE and texture output capabilities. Please observe that genlock families can not be mixed.
Video In to DVE and Texture
Output DVE |
Video In |
PAL/NTSC |
720p |
1080i |
PAL/NTSC |
OK |
720p |
1080i |
OK |
Output Texture |
Video In |
PAL/NTSC |
720p |
1080i |
PAL/NTSC |
OK |
720p |
OK |
1080i |
OK |
Clip In to DVE and Texture
Output DVE |
Clip In |
PAL/NTSC |
720p |
1080i |
PAL/NTSC |
OK |
720p |
OK |
1080i |
OK |
OK |
Output Texture |
Clip In |
PAL/NTSC |
720p |
1080i |
PAL/NTSC |
OK |
720p |
OK |
OK |
1080i |
OK |
OK |
OK |
Source: 720p
Output DVE |
Video In |
PAL/NTSC |
720p |
1080i |
PAL/NTSC |
720p |
OK |
1080i |
OK |
Output Texture |
Video In |
PAL/NTSC |
720p |
1080i |
PAL/NTSC |
OK |
720p |
OK |
1080i |
OK |
Output DVE |
Clip In |
PAL/NTSC |
720p |
1080i |
PAL/NTSC |
OK |
720p |
OK |
1080i |
OK |
OK |
OK |
Output Texture |
Clip In |
PAL/NTSC |
720p |
1080i |
PAL/NTSC |
OK |
OK |
720p |
OK |
OK |
1080i |
OK |
OK |
OK |
Source: 1080i
The first two tables show video in to DVE and texture output capabilities, while the next two tables show the clip in to DVE and texture output capabilities. Please observe that genlock families can not be mixed.
Output DVE |
Video In |
PAL/NTSC |
720p |
1080i |
PAL/NTSC |
720p |
1080i |
OK |
Output Texture |
Video In |
PAL/NTSC |
720p |
1080i |
PAL/NTSC |
OK |
720p |
OK |
1080i |
OK |
Output DVE |
Clip In |
PAL/NTSC |
720p |
1080i |
PAL/NTSC |
OK |
720p |
OK |
1080i |
OK |
OK |
OK |
Output Texture |
Clip In |
PAL/NTSC |
720p |
1080i |
PAL/NTSC |
OK |
OK |
720p |
OK |
OK |
OK |
1080i |
OK |
OK |
OK |
