Template Builder User Guide
Version 2.4 | Published November 17, 2022 ©
The Fill-in Form
Default Values in the middle of the interface contains an auto-generated form for the graphics template (the Fill In Form).
Add content in the editable fields.
The type of content allowed in the fields is set in the Edit Model window.
Fields can be restricted: for example, to only include text with a certain amount of characters, numbers within a specific range, or media placeholders for media assets, or be displayed as options in a drop-down list.
Info: Content added will be shown in the Preview Window if the fields in the Fill In Form are exposed controls made by the template designer.
Edit all: Allows editing default values of fields that are set to read-only.
Show all: Displays all fields in the form, including those in hidden mode.
Text Fields
Multi-line text: Multi-line text supports standard ASCII characters. It does not support any type of text formatting and does not convert any text. It keeps the text as it was typed.
Single-line text: A single-line text field converts any white-space to space. White-space includes space, tab, newline, etc. Single-line text converts any white-space to the space character you get by pressing the spacebar KEY only. For Template Builder, this is also a text field with a single-line entry, unlike multi-line text.
Formatted text: Formatted text refers to the ability to hold formatted text. For example, a formatted text field can show that some of the texts are bold or italic, for example, when a field has Rich-Text functionality.
Although such a display is not yet completely supported (no Rich-text support yet) on our payload text field. Formatted text is used so that if a field has a formatted type text created in Artist, the field type can also be selected in Template Builder.
