Template Builder User Guide
Version 2.4 | Published November 17, 2022 ©
Keyboard Shortcuts
This page lists available keyboard shortcuts in Template Builder.
Shortcut |
Description |
CTRL + O |
Open the Open Template dialog where you can select a template to open. |
CTRL + S |
Save a template. |
CTRL + Z |
Undo. |
CTRL + Y |
Redo. |
Warning: The shortcut CTRL + O does not work properly in Firefox version 65.0.1 and later.
Graphics Preview Player Shortcuts
Use the following shortcuts for the Graphics Preview player:
Shortcut |
Description |
SPACE or CTRL + SPACE |
Play/pause. |
SHIFT + I |
Go to the in-point. |
SHIFT + O |
Go to the out-point. |
, (comma) |
Move one frame back. |
. (period) |
Move one frame forward. |
