Viz World User Guide
Version 22.0 | Published December 15, 2022 ©
Server System Requirements
Component |
Minimum Configuration |
Recommended Configuration |
CPU |
Eight cores with 2.4 GHz frequency |
2 x Intel i7 CPU (or equivalent Intel Xeon processor) |
Memory |
8 GB |
16 GB |
Disk Space |
A full installation requires at least 2 GB of available disk space. Optional data packages require between 4 GB to 1000 GB of available disk space. |
Operating System |
Note: Viz World Server and Viz World Classic will not function while connected using Windows Remote Desktop. |
Network |
A redundant (teamed) setup with two Gigabit network adapters is recommended. |
Power Supply |
A redundant power supply is highly recommended. |
Note: When more than one server runs on a single machine, it is necessary to use the recommended system configuration described above. See Server Allocator Configuration.
