Viz World User Guide
Version 22.0 | Published December 15, 2022 ©
Getting Started with Map Editor
When the Viz World Client is installed you can start the Map Editor and connect to the Viz World Server. Once connected you are able to open existing design projects.
To Start the Map Editor
Normally the Map Editor will be launched from Viz Trio, Viz Artist or Viz Pilot.
To Connect to Viz World Server
Note: When the Map Editor is launched from a Vizrt application (e.g., Viz Trio, Viz Artist or Viz Pilot), it automatically connects to the server that has been configured within that application, rather than the server configured within the Map Editor.
Start the Map Editor.
Click the Settings button
Set the Viz World Server hostname. If not specified, the Map Editor connects to localhost.
Click Save.
