Viz Ticker User Guide
Version 4.0 | Published June 29, 2021 ©
Program Starting Sequence
After installation, the applications must be started in a specific sequence:
The Media Sequencer must be started before Ticker Wizard and Viz Ticker Client.
Note: A restart/shutdown of the Media Sequencer requires a restart/shutdown of Ticker Wizard and Viz Ticker Client.
Viz Engine must be started (and put On Air) before Ticker Wizard.
Ticker Service must be running before Ticker System is enabled in Viz Ticker Client.
Note: Ticker Wizard and Viz Ticker Client can run while starting Ticker Service.
