Viz Pilot Edge User Guide
Version 3.0 | Published January 26, 2024 ©
Introduction
Viz Pilot Edge is a newsroom component that is used to create, manage and deliver content to live and taped broadcast productions. Viz Pilot Edge can also be used as a Graphics Plugin user interface in NLE workflows.
Template Builder lets you make customized templates using the scene import or existing templates from Viz Pilot's Template Wizard.
Info: A key feature is that you can add custom HTML panels to templates, giving full control over the template through custom scripting and logic.
Key Features
Search for graphics templates, elements and media assets.
Add and edit content using an auto-generated Fill In Form.
Preview graphics.
Open and edit videos.
Save data elements to the database.
Workflow
Fill templates with content and store them as data elements.
Move data elements into the newsroom rundown.
Scenes are made in Viz Artist and imported into Template Builder, where templates are made.
Templates are edited and new templates can be made in Template Builder.
The template is saved in the Viz Pilot system and is available to newsroom and control room systems for playout.
Note: Changes in the UI made to a template in Template Builder are not available when opening the template in Template Wizard.
Related Documents
Feedback
We welcome your feedback on Vizrt products and documentation. Please contact your local Vizrt customer support team at http://www.vizrt.com.
Support
Legal
Copyright © 2024 Vizrt. All rights reserved.
Disclaimer
Antivirus
Vizrt does not recommend or test antivirus systems in combination with Vizrt products, as the use of such systems can potentially lead to performance losses. The decision for the use of antivirus software and thus the risk of impairments of the system is solely at the customer's own risk.
There are general best-practice solutions, these include setting the antivirus software to not scan the systems during operating hours and that the Vizrt components, as well as drives on which clips and data are stored, are excluded from their scans (as previously stated, these measures cannot be guaranteed).
Technical Support
For technical support and the latest news of upgrades, documentation, and related products, visit the Vizrt web site at www.vizrt.com.
