Viz Pilot Edge User Guide
Version 3.0 | Published January 26, 2024 ©
Feed Browser
If the Feed Browser functionality is configured in a template, it is possible to auto-fill in information in the data element by browsing for feed entries from a URL source. The feed entry URL is pre-set in the template.
A Browse button will then appear next to the field in the Fill-in-form.
Click Browse to open the Feed Browser.
Feed entries of the feed will be presented as thumbnails. Select one of the entries and click OK. Note that the OK button will only be enabled if the feed entry contains all the necessary information needed for the data element.
Information from the feed entry will be used to fill in fields in the fill in form, depending on how the fields in the template are linked to feed fields in Template Builder.
