Viz Multichannel
Video Preview Configuration
If you are previewing proxy versions of video from Viz One using VCP’s Newsroom Component (i.e. Timeline Editor) or Viz Engine (i.e. Viz Engine installed on your control client machine) you will have to install video codecs. These are not part of Vizrt’s standard installation.
IMPORTANT! Due to licensing requirements, Vizrt does not provide the codecs required for local preview. Users must obtain and install their own codecs.
Note: Codecs are only required when local preview is done, as in the cases above. Playout of the high resolution versions do not require a codec installation.
The following procedures will guide you through the necessary installation steps:
Installation Options
Codecs are available from several suppliers. The list below includes several suggestions:
MainConcept video decoder and splitter
IMPORTANT! On Windows 7 machines, the default installation of the LAV filters results in the LAV splitter and the Windows video decoder being used. This can lead to problems using the Timeline Editor, so customers must avoid this situation by ensuring that the LAV decoder is selected using the Windows 7 filter tweaker tool.
Note: The display accuracy of the Timeline Editor can be effected by the type of codecs installed.
Some video decoders function in a way that limits the accuracy of the Timeline Editor when displaying frames. This must be taken into account in workflows that involve accurate placement of data elements, mark-in and mark-out points, and poster frames using the Timeline Editor.
If using the FFDShow video decoder, the displayed frame for the poster frame, mark-in and mark-out features may be up to 0.5 seconds away from the position the marker is at. Customers that need a high level of frame accuracy should consider using other solutions.
The video decoders from MainConcept and LAV operate in a different way, meaning that the Timeline Editor displays frames accurately when using either of these video decoders.
Previewing videos in the Timeline Editor works accurately, regardless of the video decoder used.
Installing Codecs for Local Preview
The example below sets up support for h.264 playback using the FFDShow MPEG-4 codec package and a Matroska Splitter from Haali.
Note: You need to have your own license for clip playback as FFDShow does not come with a decoding license.
Make sure you do not have any other codec packages installed on the machine that interfere with FFDShow or the media splitter.
Download the Matroska Splitter from Haali
Download the Windows 7 DirectShow Filter Tweaker
Download the FFDShow MPEG-4 Video Decoder
Make sure you have a license to use the codec
Make sure you download a 32-bit version of the codec
Uninstall older 64-bit versions of the MPEG-4 codec
Install the *Matroska Splitter from Haali *
Install the Windows 7 DirectShow Filter Tweaker
Install the FFDShow MPEG-4 codec
After installing the FFDShow codec package make sure that no applications are excluded, especially Viz Engine (there is an inclusion and exclusion list in FFDShow).
Set your MPEG-4 *32-bit decoder to *FFDShow (see below)
You should now be able to preview video clips from Viz One
Setting a Preferred Decoder
Run the Windows 7 DirectShow Filter Tweaker
In the appearing dialog box click Preferred decoders
Set your MPEG-4/H.264 *32-bit decoder to *FFDShow and click Apply & Close
Click Exit
