Viz Multichannel
Merging Fields
The correct format for merging (joining) fields is:
freetext<at:var at:name=
"FIELDNAMEfreetext"
/>FIELDNAMEfreetext…
where free-text can be empty (FIELDNAME@FIELDNAME).
Example:@Hour:@Minute:@Second
The mapping is divided into two: one for each field reading its values, and one for concatenating (merging) them.
IMPORTANT! The merging field must be located in the table after its parts-fields.
Example 1 for fixed width Any Text import type
StartHour= $L(1,2)
StartMin= $L(3,4)
StartSecond= $L(5,6)
Begin= @StartHour:StartSecond
Example 2 for delimited Any Text import type
StartHour= $L(4)
StartMin= $L(5)
StartSecond= $L(6)
Example 3 for Any XML import type
This example shows time read in a format HH-MM-SS-FF from an entry /begin_time/time/.
TheStartTime= /begin_time/time/
StartHour= &(TheStartTime,”-”,1,1)
StartMin= &(TheStartTime,”-”,2,1)
StartSecond= &(TheStartTime,”-”,3,1)
StartFrame= &(TheStartTime,”-”,4,1)
Begin= @StartHour:@StartMin:@StartSecond:@StartFrame
