Viz Multichannel
ADC-100 by Harris Broadcast
This section covers configuring the Automated Content Management and Distribution system (ADC-100) by Harris Broadcast for Viz Multichannel. It describes the setup on the ADC side and contains information on the following topics:
General Information and Setup
An ADC-100 system can trigger Viz Multichannel (by sending commands to Media Sequencer) through VDCP or Universal Sercom Device (USD) using either TCP/IP or VDCP.
Note: Both version 11 and 12 of the LST format is supported.
Advantages of VDCP are:
Standard
Proved to work for many customers
Advantages of USD are:
Can be used over TCP/IP thus saving serial ports and additional cabling
Triggering
Triggering should be Primary/Secondary Events selected.
Primary Event Defaults should be Triggered (Ext) selected. The ADC-100 system reads playlist data via files in LST format (binary files).
Reconcile field value in the LST is read into the Event ID field in Viz Multichannel and is must be set in order to receive playlist updates. An empty or corrupted Reconcile value will omit that event from the update procedure.
If primary events triggering is selected then Viz Multichannel can import the same LST file that is provided by the ADC-100 system because the data required for the triggering is available in it.
If secondary events triggering is selected and all Vizrt secondary events are received from the scheduling system (i.e. in the LST file) then Viz Multichannel can import the same LST file that is provided by the ADC-100 system because the data required for the triggering is available in it (as long as secondary events contain assigned ID fields).
If secondary events triggering is selected and there are Vizrt secondary events that are generated by Viz Multichannel (manually or by import rules) then Viz Multichannel must export a new LST with the data required for the triggering in it.
Updating LST by Export
While exporting Viz Multichannel will make sure all secondary events have a Media ID value assigned (if secondary events triggering is selected) and assign it to the LST ID field.
Either exporting LST from scratch or merging into the original LST is optional. Merging is preferable since it only appends the new secondary events to the LST file and will assure that original data is not touched.
Updating LST by Import
Two mapping options are available, either with or without secondary events.
Refer to (folder path) folder in Viz Multichannel installation for sample mapping settings and playlists.
Channel name can be read from the filename. If filename does not contain a channel identifier, either do not map channel value or set Traffic Channel Name to 1 in Viz Multichannel’s Basic Settings.
Updating Live
Recovery (RCV): The Harris ADC-100 can auto-generate a recovery file (*.RCV) on every playlist change. RCV files are in LST format. Viz Multichannel can monitor a folder and update its playlist according to the RCV file once it is generated.
Broadcast Exchange Format (BXF): Viz Multichannel supports processing BXF schedules.
LST files managed by Schedule Collector tool: Schedule Collector can monitor a folder for LST update files. Using its cache memory, updates will be attempted only for changed events.
Limitations
The LST format only allows for 32 character titles and misses other necessary fields such as local language titles.
Allow replay – Media Sequencer virtually removes played events from its exposable list, so Vizrt events will be marked as MISSED on ADC-100 side although played successfully.
Trigger Viz Multichannel Using VDCP
The standard configuration of Viz Multichannel is triggering by a serial connection using Video Disk Control Protocol (VDCP).
Any Device Server version allows controlling Viz Multichannel, provided that it has a Video Disk driver.
Connections
Use an RS422 board on the machine with Media Sequencer, for example: Blue Heat/PCI of Connect Tech Inc. The following custom cables are required to connect the Media Sequencer to the ADC-100 system.
ADC-100 to Media Sequencer: Connections
ADC-100 |
Media Sequencer Machine |
2 (Rx -) |
2 (Tx -) |
3 (Tx +) |
3 (Rx +) |
7 (Rx +) |
7 (Tx +) |
8 (Tx -) |
8 (Rx -) |
Device Configuration
To Configure the Software
Make sure that under Windows Configuration on the Media Sequencer machine, the COM port used has the following suggested parameters.
Bits per second: 38400
Data bits: 8
Parity: Odd
Stop bits: 1
Flow control: None
Enable the VDCP device on Viz Multichannel and ensure it is configured properly with that port and also turned on.
To Configure the Viz driver
Launch the ADC-100 Configuration Utility and locate the icon that represents your Device Server.
Right-click the icon, and select Configured Devices.
In the Available column on the left, locate the Standard Video Disk driver under the Video Disk category. Click and drag the driver to one of the channels on the Configured column that reads NO DEVICE.
Double-click on the Disk device that was just created. From the resulting dialog select the* Serial Port* tab.
Select the physical port the Media Sequencer is connected to. The Harris Device Server is now configured properly to communicate with the Media Sequencer.
Configure the following parameters on the General tab:
Device Name will appear in the Device Status and configuration windows on the client applications. The default name may be used, but it is recommended to use unique names for easy identification later.
ID Match Name will be used in the Transmission List’s *ID Field *to let the system know that the event is intended for the Vizrt device.
Stop Disk Play can be set or not depending on the need.
Back to Back Play can be set or not depending on the need.
Update Event Duration from Disk must be unchecked.
The Vizrt Standard Video Disk must also be assigned to a Transmission List to be schedule to air.
Note: If you are using Extended IDs, you may not use the Standard Video Disk driver. Additionally, the Media Sequencer does not have the notion of duration, so the parameter Update Duration from Disk must be unchecked to avoid too many error messages when ADC driver asks for the IDs list.
Operation
Viz Multichannel uses Secondary A/V or Secondary Backtimed events to execute the pre-loading and playout of media.
Trigger Viz Multichannel Using USD
When configuring Viz Multichannel to be triggered by a Universal Sercom Device (USD) driver you can either configure it to use TCP or Serial Communication.
USD Device Configuration
To Configure the Vizrt Driver
Right-click the icon, and select* Configured Devices*.
In the Available column on the left, under the Advanced Devices category, locate the Universal Sercom Driver. Click and drag the driver to one of the channels in the Configured column that reads NO DEVICE.
A new device will appear in the left pane of Configured Devices main window.
Right-click the new device and select Properties.
In* General* tab replace default name and ID with VIZRT001 and click Apply.
In Connection tab, insert Media Sequencer machine’s IP/Host or Serial value and the Port (for TCP) as configured in Viz Multichannel TCP or VDCP device settings.
In Macros tab click the Add button to create a new macro.
The Extended Macro Entry dialog is displayed. -
In the Cue tab set the* Macro Name* to VIZRT.
Set the Number of Parameters to 1.
Check the Command check box.
In the Command field, enter the command to be used.
To edit the graphics stopping macro string, click the End tab.
Play will be triggered when an event starts. End will be triggered when an event ends.
Notes
When an event is triggered (primary or secondary), the command take id is sent where id is the Media ID value in Viz Multichannel and ID field value in ADC-100.
Harris playlist (.LST) USD format:*
TITLE field: macro_name:trigger_id (Media ID). For example: VIZRT:MCP2
ID field: USD_NAME (device) name
Reconcile Key field: Template name
Harris macro format: trigger_command [1]{D0A}. For example: PAGE_START [1] {D0A}. {D0A} is the char symbol for Enter.
Operation
Viz uses A/V, Secondary A/V to execute the pre-loading and playout of media.
Automatic Playlist Updates Using RCV Files
Auto List Save allows automatic list savings based on the number of list changes that occur on an active on-air transmission list.
Number of changes value indicates how often the list is automatically saved to an RCV file.
RCV file will be read by Multichannel and update its playlist accordingly.
To Enable Auto List Save
From the main menu select Properties > Auto List Save. The Auto List Save dialog is displayed.
Click the Add button.
The Choose List dialog is displayed. -
Select a list from the Available Lists pane and click OK.
The Save Options dialog displayed. -
Save LookAhead: (Default: enabled) Check to enable save of the list look ahead only.
Save Full: Check to enable save of the full list
Save Frequency: (Default: 10) Specify the number of changes required before a list save is initiated. This is the value of how many events go by NOT how many "edits" are performed.
Save Directory: Specify the save directory for the saved list. (Click ’…’ to browse for a location.) Viz Multichannel will scan the specified folder for new RCV file updates.
Click OK.
The list is added to the Enabled Lists pane.
