Viz Multichannel
Configuring Import and Update Folders for Network Drives
A Windows service does not have access to network drives mapped with aliases such as M:\ when mapped using a regular domain user.
The following procedures describe how to configure Viz Multichannel to use network drives for playlist imports and updates when running Media Sequencer as a Windows Service.
To Set Playlist Imports and Update Destination Path for Schedule Files
Start Viz Multichannel in Scheduling mode
Open the configuration settings
Click General Settings under the Import/Export Settings category for Channel Settings
Set the destination path for the schedule files to import or update
Note: For this case network paths, such as UNC paths (e.g. \network\...) are supported; however, mapped drives are not.
To Enable Automatic Import
Click Automatic Import under the Import/Export settings category for Global Settings
Set the automatic import interval, playlist importer folder path, and the playlist importer log level
To Configure Media Sequencer Network Authentication
In Windows, click Start
Open the Control Panel, select System and Security and then Administrative Tools
Open Services
Select and right-click the Vizrt Media Sequencer service and select Properties from the appearing context menu
Select the Log On tab
Select the “This account” option
Enter a username and password that has access to the network share you want to connect to
Apply and click OK
Note: If the Vizrt Media Sequencer service is already running, please restart the service for the new settings to take effect.
Troubleshooting
Microsoft Excel schedule files cannot be imported
Microsoft Excel and other Microsoft Office applications are not designed to be run as a server application, and Microsoft does not support this usage
Create a folder named Desktop in the following location:
32-bit systems: C:\Windows\System32\config\systemprofile
64-bit systems: C:\Windows\SysWOW64\config\systemprofile
For more information, see the following knowledge base article on Arcana Development and/or the following Microsoft knowledge base article on Considerations for server-side automation of Office.
