Viz Mosart User Guide
Version 5.0 | Published June 21, 2022 ©
Viz Mosart User Interface
The Viz Mosart GUI (Multi GUI) is the main control interface for operators and can be customized to suit your workflow.
You run the GUI either on the Mosart server or with one or more GUIs connected over the Mosart server network.
A common customization is having user action shortcuts on a separate touch-enabled screen, detaching the keys to a floating window.
View > Floating windows > Function buttons.
The areas of the Viz Mosart GUI are described in the following sections:
In addition, the following editors/panels can also be opened or configured as part of the layout:
