Viz Mosart User Guide
Version 5.0 | Published June 21, 2022 ©
Mosart ActiveX
Page is under construction and will not appear in final documentation (talk to Doc Team)
To open Mosart ActiveX from ENPS client
Right-click on the MOS icon from bottom right
Select the Mosart ActiveX given by the name configured in MOS Configuration
(in our example Mosart@LBU).
If several Viz Mosart MOS devices are configured, any of them would work to open Viz Mosart ActiveX.
Template type MACRO
(used for sequences)
See also:
Section Linking Device Properties and Newsroom Tags on page Template Device Functions in the Viz Mosart Administrator Guide
Section Additional Template Functionality in the Viz Mosart Administrator Guide under AV Automation.
