Viz Mosart User Guide
Version 5.0 | Published June 21, 2022 ©
Recalling a Workspace/Keyboard Layout by Control Command from a Template
A work space and keyboard layout can be recalled with a control command. This control command can be added to a template.
This could be, for example, a BREAK that is invoked at the beginning of a show.
In AVAutomation, select Template Editor.
From the Template properties dialog, select the Control Commands tab.
Under the Command column drop-down menu, select GUI.
Under the Value column drop-down menu, select WORKSPACE.
In the Parameter column, enter the name of the Workspace (the naming must exist in the Viz Mosart UI).
