Viz Mosart User Guide
Version 5.0 | Published June 21, 2022 ©
On Air Shortcut Operations
Working with Template Shortcut Keys
You can speed-up access to operations that are defined in a template by assigning the template to a Viz Mosart shortcut key, by drag and drop.
All secondary items, including lower thirds and audio files in a template shortcut are are also added.
Template Shortcut Key Operations
To Add a Template Element to a Keyboard Shortcut Button
From the Media Pool, drag an element from the Asset, Favorites or the Quick Access tab (see illustration above).
Drop on a selected Viz Mosart shortcut key.
The selection is saved in your keyboards setup.
To Clear a Template Element from a Keyboard Shortcut Button
Right-click on the button you wish to clear.
Depending on the defined content either:
From the context menu, choose Clear.
Where secondary items are included, choose Clear sub items.
Where NCS-bound keys are included, reset them to their original state by choosing Reset.
