Tracking Hub
Version 1.1.1 | Published April 03, 2018 ©
Topology Panel
The Topology Panel shows a representation of the tracking systems, the connection to a Viz Engine and which Viz Engine services are in use.
Tracking Systems
The Tracking System panel represents the tracking software in the studio.
Click on a tracking system icon to view its properties (see Parameter Panel).
A line from the tracking system represents a connection to a Rig.
Right-click Menu:
Connect to: Connect to a Rig.
Connect/Disconnect: Connect or disconnect to the tracking system.
Analyze timing: See Analyze Time.
Analyze rawdata: Click to enable or disable the collection of raw data for analytical purposes.
Delete: Remove the Tracking System.
Right-click on a Bar:
Reset bar’s min/max: Reset the minimum and maximum value of each bar.
Reset spectrum’s min/max: Reset the minimum and maximum value of the whole spectrum and each bar
Rigs
A Rig is the interface between the Tracking System and the Viz Engine. Click on any Rig icon to view its properties (see Parameter Panel).
A line from a Rig on the left represents a connection to a tracking system (see Tracking Systems). A line from a Rig on the right represents a connection to a Service (see Services).
Rigs are defined as the following types:
Translation
Arm
Location Pivot Rotation
Pivot Rotation
Camera
Object
The Translantion rig is for position data only, and provides the Tracking Hub with the following parameters:
pos_x
pos_y
pos_z
The Arm rig can be rotated in 3 dimensions, and starts with a swivel. It has a defined length with a defined direction, and offsets between swivel and length.
Both the Translation and Arm rigs are used for camera systems such as Spidercam:
The Location Pivot Rotation rig is a rotation interface in the X-Z dimension, with center point (0/0).
Pivot Rotation is a rotation rig with a definable center point. The rig provides the Tracking Hub with the following coordinates:
pivotx
pivoty
pivotz
Camera is a basic rig for tracked cameras.
Object is a basic object for tracked objects.
Services
A Service is the element of a Viz Engine which is connected to the Tracking System through the Rig.
Click on a Service icon to view its properties (see Parameter Panel).
A line from the a Service represents a connection to a Rig (see Rigs).
Services available are:
Camera: Track a with a Viz Engine camera.
Object: Track an object with Viz Engine.
Parameter: Provides all required data for the creation of the 3d View.
Communication Timing: Sends timing information which are measured during tracking data acquisition.
Tracking Timing: Sends timing information which are measured during sending the data as service to the engines.
Right-click displayed object for additional menu:
Topology Connection Lines
The Topology Connection Lines show the connections between each item in the Topology. Double-clicking a Topology connection line between a Tracking System and a Rig opens the Tracking parameter routing window for the connection:
Topology Colors
The colors of the icons in the Topology view show the working condition:
Green: Everything is OK and in regular working condition.
Grey: The tracker is not connected or deactivated.
Orange: The Service or Tracker state is in warning condition. See the log or message for more information.
Red: The Tracker or Service is in a serious error state. See log or message for more information.
