Viz Licensing Administrator Guide
Version 2.0 | Published December 03, 2018 ©
Troubleshooting
I am using a license server and the application does not start because no license was found
License Activation fails
Your Ticket cannot be found
Contact your Sales Account Manager or your region's Vizrt Licensing department, so that they can verify that the ticket is associated with the correct account, or if adjustments are required.
This ticket is deactivated
The activation process was most likely interrupted causing the licenses not to upload successfully. Contact your region's Vizrt Licensing department so they can issue a new ticket.
This ticket is already activated
The licenses of this ticket have already been uploaded successfully.
The connection could not be established
The Vizrt Licensing Service could not be reached during the ticket activation process. Check the service status and make sure it is running.
Your container cannot be activated for the following reasons - feature xxx already exists...
The current ticket contains one or several features which have already been activated in this container. Install the licenses on a different machine. If the licenses are intended for this machine, contact the Sales Account Manager or your region's Vizrt Licensing department so that they can send you a license extension for your container instead.
