Viz Licensing Administrator Guide
Version 2.0 | Published December 03, 2018 ©
Supported Products
  • Viz Engine 3.10 or higher for all deployments.
  • Graphic Hub 3.1.0 or higher.
  • Viz Virtual Studio 1.1.1 or higher.
    Info: Viz Engine requires a virtual GPU to run inside a virtual environment. Please refer to the Viz Engine Release Notes and Documentation about supported virtual GPUs.
    Info: Viz Engine does not start up if you are connected via Remote Desktop or TeamViewer, as they do not allow for OpenGL output. You might consider using a VNC client, for example TightVNC, as an administrative back-end tool.
