Viz Licensing Administrator Guide
Version 2.0 | Published December 03, 2018 ©
Amazon AWS Cloud
To ensure the full functionality of your Vizrt licenses after a restore, please follow the steps below for creating a supported back-up.
Create Volume snapshot
Step 1: Under the Description tab for the instance, you can see the block device(s) for this particular instance.
images/download/thumbnails/37567284/aws1.png
Step 2: Click on the block device to check the volume's EBS ID. If there is just one volume available in the server, then this volume should be the same as the root device. This becomes the volume for the snapshot.
images/download/attachments/37567284/aws2.png
Step 3: Click on the EBS ID to get to the volume overview.
images/download/attachments/37567284/aws3.png
Then, you right-click the volume and select Create Snapshot.
images/download/attachments/37567284/aws4.png
images/download/attachments/37567284/aws5.png
Step 4: After you have created the snapshot, you may find it in the snapshot overview. Right-click and select Create Volume.
images/download/thumbnails/37567284/aws6.png
Step 5: In the Create Volume-wizard, you must be sure to choose the correct value in the Availability Zone* input field, so that the volume is available to where your virtual machine is located. After you have created the volume, it is visible in the volume overview.
images/download/attachments/37567284/aws7.png
Restore
To restore the state of the virtual machine to the state of this volume, you must first detach the damaged/old volume in the virtual machine. Next, attach the virtual machine volume to the instance from which the snapshot has been taken by right-clicking the volume and selecting Attach Volume.
images/download/thumbnails/37567284/aws8.png
Select the correct instance and enter /dev/sda1 into the Device input field. This sets your volume to be your boot volume.
images/download/attachments/37567284/aws9.png
After completing this step, the virtual machine can be turned on again. It is now using a valid license.
