POST a Secondary Event under Group Event in Channel Pool (Version 2.0)
Add one secondary event to an existing group event. There are several types of secondary events, examples below.
Attempting to add a secondary event that already exists, will return a 'HTTP 409 Can't add secondary event 'NNN', it already exists'.
POST /api/channels/[channel]/channel_pool/events/[group_event]/secondaryevents
Secondary event page
Description, duration, trigger id, offset, created by and metadata can be empty.
Name and page id cannot be empty. Attempting to add a secondary event with page id does not exist in page pool, will return a 'HTTP 400 Can't create secondary page event, page 'NNN' does not exist'.
Description is set from the page of given page id, if left empty.
Duration is set from the page of the given page id, if left empty.
Created by defaults to "inthub" if empty.
If any values are set for is manually edited, loaded, available, info integrations hub, info promo server and take count, the payload will be accepted but the values will be ignored as they can't be set.
POST /api/channels/test/channel_pool/events/group_1/secondaryevents HTTP/1.1
Content-Type: application/vizrt.integrationshubv2+xml; type=secondaryevent
inthub
:secondaryEvent
xmlns:xsi
"http://www.w3.org/2001/XMLSchema-instance"
xsi:type
"inthub:pageEvent"
xmlns:inthub
"http://www.vizrt.com/integrationshub"
inthub
:name>secondary_1_1</
inthub
:name>
inthub
:description>not used</
inthub
:description>
inthub
:offset>00:00:10.000</
inthub
:offset>
inthub
:duration>00:00:20.000</
inthub
:duration>
inthub
:pageId>6000</
inthub
:pageId>
inthub
:triggerId>735</
inthub
:triggerId>
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:secondaryEvent>
HTTP/1.1 201 Created
inthub
:secondaryEvent
xmlns:xsi
xsi:type
"inthub:pageEvent"
xmlns:inthub
inthub
inthub
:name>
inthub
:refLink
rel
"self"
type
"application/vizrt.integrationshubv2+xml; type=secondaryevent"
href
"http://127.0.0.1:9991/api/channels/test/channel_pool/events/group_1/secondaryevents/secondary_1_1"
inthub
:refLink
rel
"edit"
type
href
inthub
:refLink
rel
"pagecontent"
type
"application/vizrt.integrationshubv2+xml; type=pagecontent"
href
"http://127.0.0.1:9991/api/channels/test/channel_pool/events/group_1/secondaryevents/secondary_1_1/pagecontent"
inthub
inthub
:description>
inthub
:triggerId>735</
inthub
:triggerId>
inthub
inthub
:offset>
inthub
:takeCount>0</
inthub
:takeCount>
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:infoIntegrationsHub>[A:15:56:49]</
inthub
inthub
:loaded />
inthub
:available />
inthub
:isManuallyEdited>false</
inthub
:isManuallyEdited>
inthub
inthub
:duration>
inthub
:pageId>6000</
inthub
:pageId>
inthub
:infoPromoServer />
inthub
:metadata />
inthub
:secondaryEvent>
Secondary event reference page
Description, duration, trigger id, offset and created by can be empty.
Name and page id cannot be empty. Attempting to add a reference secondary event with page id does not exist in page pool, will return a 'HTTP 400 Can't create reference secondary page event, page 'NNN' does not exist'.
If any values are set for is manually edited, loaded, available, info integrations hub and take count, the payload will be accepted but the values will be ignored as they can't be set.
inthub
:secondaryEvent
xmlns:xsi
xsi:type
"inthub:refPageEvent"
xmlns:inthub
inthub
:name>secondary_1_ref</
inthub
:name>
inthub
:description>Default Logo</
inthub
:description>
inthub
inthub
:offset>
inthub
inthub
:duration>
inthub
:pageId>6000</
inthub
:pageId>
inthub
:triggerId>735</
inthub
:triggerId>
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:secondaryEvent>
inthub
:secondaryEvent
xmlns:xsi
xsi:type
xmlns:inthub
inthub
inthub
:name>
inthub
:refLink
rel
"self"
type
href
"http://127.0.0.1:9991/api/channels/test/channel_pool/events/group_1/secondaryevents/secondary_1_ref"
inthub
:refLink
rel
"edit"
type
href
inthub
inthub
:description>
inthub
:triggerId>735</
inthub
:triggerId>
inthub
inthub
:offset>
inthub
:takeCount />
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:infoIntegrationsHub>[A:16:10:05]</
inthub
inthub
:loaded />
inthub
:available />
inthub
inthub
:isManuallyEdited>
inthub
inthub
:duration>
inthub
:pageId>6000</
inthub
:pageId>
inthub
:secondaryEvent>
Secondary event action
Description, trigger id, offset and created by can be empty.
Name and action id cannot be empty. Attempting to add a secondary action event with action id does not exist in action pool, will return a 'Can't create secondary action event, action 'NNN' does not exist'.
Description is set from the action of given action id, if left empty.
If any values are set for is manually edited, loaded, available, info integrations hub, take count, action command and action category, the payload will be accepted but the values will be ignored as they can't be set.
inthub
:secondaryEvent
xmlns:xsi
xsi:type
"inthub:actionEvent"
xmlns:inthub
inthub
:name>secondary_1_action</
inthub
:name>
inthub
:description>A cleanup action</
inthub
:description>
inthub
inthub
:offset>
inthub
:actionId>viz_cleanup</
inthub
:actionId>
inthub
:triggerId>735</
inthub
:triggerId>
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:secondaryEvent>
inthub
:secondaryEvent
xmlns:xsi
xsi:type
xmlns:inthub
inthub
inthub
:name>
inthub
:refLink
rel
"self"
type
href
"http://127.0.0.1:9991/api/channels/test/channel_pool/events/group_1/secondaryevents/secondary_1_action"
inthub
:refLink
rel
"edit"
type
href
inthub
inthub
:description>
inthub
:triggerId>735</
inthub
:triggerId>
inthub
inthub
:offset>
inthub
:takeCount />
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:infoIntegrationsHub>[A:16:24:12]</
inthub
inthub
:loaded />
inthub
:available />
inthub
inthub
:isManuallyEdited>
inthub
inthub
:actionId>
inthub
:actionCommand>SCENE CLEANUP</
inthub
:actionCommand>
inthub
:actionCategory>viz</
inthub
:actionCategory>
inthub
:secondaryEvent>
Secondary event pilot data element
Name and pilot data element id cannot be empty. Pilot data element id must be an integer.
inthub
:secondaryEvent
xmlns:xsi
xsi:type
"inthub:pilotDataElementEvent"
xmlns:inthub
inthub
:name>secondary_1_pde</
inthub
:name>
inthub
:description>Pilot data element</
inthub
:description>
inthub
inthub
:offset>
inthub
inthub
:duration>
inthub
:pilotDataElementId>9000</
inthub
inthub
:triggerId>735</
inthub
:triggerId>
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:secondaryEvent>
inthub
:secondaryEvent
xmlns:xsi
xsi:type
xmlns:inthub
inthub
inthub
:name>
inthub
:refLink
rel
"self"
type
href
"http://127.0.0.1:9991/api/channels/test/channel_pool/events/group_1/secondaryevents/secondary_1_pde"
inthub
:refLink
rel
"edit"
type
href
inthub
inthub
:description>
inthub
:triggerId>735</
inthub
:triggerId>
inthub
inthub
:offset>
inthub
:takeCount />
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:infoIntegrationsHub>[A:16:16:30]</
inthub
inthub
:loaded />
inthub
:available />
inthub
inthub
:isManuallyEdited>
inthub
inthub
:duration>
inthub
inthub
inthub
:secondaryEvent>
Secondary event message
Description, offset and created by can be empty.
Name cannot be empty.
If any values are set for info integrations hub, the payload will be accepted but the values will be ignored as they can't be set.
inthub
:secondaryEvent
xmlns:xsi
xsi:type
"inthub:msgEvent"
xmlns:inthub
inthub
:name>secondary_1_message</
inthub
:name>
inthub
:description>This is a message</
inthub
:description>
inthub
inthub
:offset>
inthub
:createdBy>schedule</
inthub
:createdBy>
inthub
:secondaryEvent>
inthub
:secondaryEvent
xmlns:xsi
xsi:type
"inthub:msgEvent"
xmlns:inthub
inthub
inthub
:name>
inthub
:refLink
rel
"self"
type
href
"http://127.0.0.1:9991/api/channels/test/channel_pool/events/group_1/secondaryevents/secondary_1_message"
inthub
:refLink
rel
"edit"
type
href
inthub
inthub
:description>
inthub
inthub
:offset>
inthub
inthub
:createdBy>
inthub
:infoIntegrationsHub>[A:14:55:14]</
inthub
inthub
:secondaryEvent>
Note: The full contract can be used for POST, fields that are read only will be ignored.
