PUT on Secondary Event under a Primary Event in Playlist (Version 2.0)
Update a Secondary Event definition. There are several types of secondary events, examples below.
Note: After this request is done the system performs a Page Content Filling process against Promo Server as soon as there is no immediate additional requests sent.
PUT /api/channels/[channel]/playlists/[playlist]/primaryevents/[primary_event]/secondaryevents/[secondary_event]
Secondary event page
Name, page id and created by can't be adjusted from it's original value.
Description, duration, trigger id, offset and metadata can be empty.
Metadata section will update completely according to how it is specified. If the metadata section is empty, all metadata will be removed. If a metadata attribute is removed, then that metadata will be removed. If metadata values are updated, they will be updated accordingly.
If any values are set for is manually edited, loaded, available, info integrations hub, info promo server and take count, the payload will be accepted but the values will be ignored as they can't be set.
PUT /api/channels/test/playlists/continuous/primaryevents/primary_element_2_0_0/secondaryevents/secondary_1_1 HTTP/1.1
Content-Type: application/vizrt.integrationshubv2+xml; type=secondaryevent
inthub
:secondaryEvent
xmlns:xsi
"http://www.w3.org/2001/XMLSchema-instance"
xsi:type
"inthub:pageEvent"
xmlns:inthub
"http://www.vizrt.com/integrationshub"
inthub
:name>secondary_1_1</
inthub
:name>
inthub
:description>new description</
inthub
:description>
inthub
:offset>00:00:05.000</
inthub
:offset>
inthub
:duration>00:00:01.000</
inthub
:duration>
inthub
:pageId>6000</
inthub
:pageId>
inthub
:triggerId>735</
inthub
:triggerId>
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:metadata>
inthub
:attribute
name
"date"
>2022-03-10</
inthub
:attribute>
inthub
:attribute
name
"time"
>21:00:00:00</
inthub
:attribute>
inthub
:attribute
name
"event_type"
>SECONDARY</
inthub
:attribute>
inthub
:attribute
name
"some_metadata"
>this shows random metadata</
inthub
:attribute>
inthub
:metadata>
inthub
:secondaryEvent>
HTTP/1.1 200 OK
inthub
:secondaryEvent
xmlns:xsi
xsi:type
"inthub:pageEvent"
xmlns:inthub
inthub
inthub
:name>
inthub
:refLink
rel
"self"
type
"application/vizrt.integrationshubv2+xml; type=secondaryevent"
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/primary_element_2_0_0/secondaryevents/secondary_1_1"
inthub
:refLink
rel
"edit"
type
href
inthub
:refLink
rel
"pagecontent"
type
"application/vizrt.integrationshubv2+xml; type=pagecontent"
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/primary_element_2_0_0/secondaryevents/secondary_1_1/pagecontent"
inthub
inthub
:description>
inthub
:triggerId>735</
inthub
:triggerId>
inthub
inthub
:offset>
inthub
:takeCount>0</
inthub
:takeCount>
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:infoIntegrationsHub>[U:17:15:15]</
inthub
inthub
:loaded />
inthub
:available />
inthub
:isManuallyEdited>false</
inthub
:isManuallyEdited>
inthub
inthub
:duration>
inthub
:pageId>6000</
inthub
:pageId>
inthub
:infoPromoServer />
inthub
:metadata>
inthub
:attribute
name
"date"
>2022-03-10</
inthub
:attribute>
inthub
:attribute
name
"time"
>21:00:00:00</
inthub
:attribute>
inthub
:attribute
name
"event_type"
>SECONDARY</
inthub
:attribute>
inthub
:attribute
name
"some_metadata"
inthub
:attribute>
inthub
:metadata>
inthub
:secondaryEvent>
Secondary event reference page
Description, duration, trigger id and offset can be empty.
If any values are set for is manually edited, loaded, available, info integrations hub and take count, the payload will be accepted but the values will be ignored as they can't be set.
PUT /api/channels/test/playlists/continuous/primaryevents/primary_1/secondaryevents/secondary_1_ref HTTP/1.1
inthub
:secondaryEvent
xmlns:xsi
xsi:type
"inthub:refPageEvent"
xmlns:inthub
inthub
:name>secondary_1_ref</
inthub
:name>
inthub
:description>New Logo</
inthub
:description>
inthub
:offset>00:00:10.000</
inthub
:offset>
inthub
:duration>00:00:20.000</
inthub
:duration>
inthub
:pageId>6000</
inthub
:pageId>
inthub
:triggerId>735</
inthub
:triggerId>
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:secondaryEvent>
HTTP/1.1 200 OK
inthub
:secondaryEvent
xmlns:xsi
xsi:type
xmlns:inthub
inthub
inthub
:name>
inthub
:refLink
rel
"self"
type
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/primary_1/secondaryevents/secondary_1_ref"
inthub
:refLink
rel
"edit"
type
href
inthub
inthub
:description>
inthub
:triggerId>735</
inthub
:triggerId>
inthub
inthub
:offset>
inthub
:takeCount />
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:infoIntegrationsHub>[U:17:10:05]</
inthub
inthub
:loaded />
inthub
:available />
inthub
inthub
:isManuallyEdited>
inthub
inthub
:duration>
inthub
:pageId>6000</
inthub
:pageId>
inthub
:secondaryEvent>
Secondary event action
Name, action id and created by can't be adjusted from it's original value.
Description, trigger id, offset and action command can be empty.
If any values are set for is manually edited, loaded, available, info integrations hub, take count and action category, the payload will be accepted but the values will be ignored as they can't be set.
PUT /api/channels/test/playlists/continuous/primaryevents/primary_1/secondaryevents/secondary_1_action HTTP/1.1
inthub
:secondaryEvent
xmlns:xsi
xsi:type
"inthub:actionEvent"
xmlns:inthub
inthub
:name>secondary_1_action</
inthub
:name>
inthub
:description>A cleanup action</
inthub
:description>
inthub
inthub
:offset>
inthub
:actionId>viz_cleanup</
inthub
:actionId>
inthub
:triggerId>735</
inthub
:triggerId>
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:actionCommand>SCENE CLEANUP 1</
inthub
:actionCommand>
inthub
:secondaryEvent>
HTTP/1.1 200 OK
inthub
:secondaryEvent
xmlns:xsi
xsi:type
xmlns:inthub
inthub
inthub
:name>
inthub
:refLink
rel
"self"
type
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/primary_1/secondaryevents/secondary_1_action"
inthub
:refLink
rel
"edit"
type
href
inthub
inthub
:description>
inthub
:triggerId>735</
inthub
:triggerId>
inthub
inthub
:offset>
inthub
:takeCount />
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:infoIntegrationsHub>[U:16:34:12]</
inthub
inthub
:loaded />
inthub
:available />
inthub
inthub
:isManuallyEdited>
inthub
inthub
:actionId>
inthub
inthub
:actionCommand>
inthub
:actionCategory>viz</
inthub
:actionCategory>
inthub
:secondaryEvent>
Secondary event pilot data element
Name, pilot data element id and created by can't be adjusted from it's original value.
PUT /api/channels/test/playlists/continuous/primaryevents/primary_1/secondaryevents/secondary_1_pde HTTP/1.1
inthub
:secondaryEvent
xmlns:xsi
xsi:type
"inthub:pilotDataElementEvent"
xmlns:inthub
inthub
:name>secondary_1_pde</
inthub
:name>
inthub
:description>Pilot data element</
inthub
:description>
inthub
:offset>00:00:12.000</
inthub
:offset>
inthub
inthub
:duration>
inthub
:pilotDataElementId>9000</
inthub
inthub
:triggerId>735</
inthub
:triggerId>
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:secondaryEvent>
HTTP/1.1 200 OK
inthub
:secondaryEvent
xmlns:xsi
xsi:type
xmlns:inthub
inthub
inthub
:name>
inthub
:refLink
rel
"self"
type
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/primary_1/secondaryevents/secondary_1_pde"
inthub
:refLink
rel
"edit"
type
href
inthub
inthub
:description>
inthub
:triggerId>735</
inthub
:triggerId>
inthub
inthub
:offset>
inthub
:takeCount />
inthub
:createdBy>inthub</
inthub
:createdBy>
inthub
:infoIntegrationsHub>[U:21:10:30]</
inthub
inthub
:loaded />
inthub
:available />
inthub
inthub
:isManuallyEdited>
inthub
inthub
:duration>
inthub
inthub
inthub
:secondaryEvent>
Secondary event message
Name and created by can't be adjusted from it's original value.
Description and offset can be empty.
If any values are set for info integrations hub, the payload will be accepted but the values will be ignored as they can't be set.
PUT /api/channels/test/playlists/continuous/primaryevents/primary_1/secondaryevents/secondary_1_message HTTP/1.1
inthub
:secondaryEvent
xmlns:xsi
xsi:type
"inthub:msgEvent"
xmlns:inthub
inthub
:name>secondary_1_message</
inthub
:name>
inthub
:description>This is an updated message</
inthub
:description>
inthub
inthub
:offset>
inthub
:createdBy>schedule</
inthub
:createdBy>
inthub
:secondaryEvent>
HTTP/1.1 200 OK
inthub
:secondaryEvent
xmlns:xsi
xsi:type
"inthub:msgEvent"
xmlns:inthub
inthub
inthub
:name>
inthub
:refLink
rel
"self"
type
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/primary_1/secondaryevents/secondary_1_message"
inthub
:refLink
rel
"edit"
type
href
inthub
inthub
:description>
inthub
inthub
:offset>
inthub
inthub
:createdBy>
inthub
:infoIntegrationsHub>[U:14:57:04]</
inthub
inthub
:secondaryEvent>
