GET a Secondary Event under Primary Event in Playlist (Version 2.0)
Following the downlink while retrieving the collection of Secondary Events under a Primary Event one can also do a GET directly on a single Secondary Event.
Take note that the content depends on the type of Secondary Event, and the collection of entries under meta_data sub-section is not set in size or content, and depends on the actual meta data attributes on the secondary events in the playlist.
Syntax
GET /api/channels/[channel]/playlists/[playlist]/primaryevents/[primary_event]/secondaryevents/[secondary_event]
Request
GET /api/channels/test/playlists/continuous/primaryevents/primary_element_1_0_0/secondaryevents/f4e0a087-c6f4-4f40-bca9-a51cdaf43634 HTTP/1.1
Response
HTTP/1.1 200 OK
Content-Type: application/vizrt.integrationshubv2+xml; type=secondaryevent
inthub
:secondaryEvent
xmlns:xsi
"http://www.w3.org/2001/XMLSchema-instance"
xsi:type
"inthub:pageEvent"
xmlns:inthub
"http://www.vizrt.com/integrationshub"
inthub
:name>f4e0a087-c6f4-4f40-bca9-a51cdaf43634</
inthub
:name>
inthub
:refLink
rel
"self"
type
"application/vizrt.integrationshubv2+xml; type=secondaryevent"
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/primary_element_1_0_0/secondaryevents/f4e0a087-c6f4-4f40-bca9-a51cdaf43634"
inthub
:refLink
rel
"edit"
type
href
inthub
:refLink
rel
"pagecontent"
type
"application/vizrt.integrationshubv2+xml; type=pagecontent"
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/primary_element_1_0_0/secondaryevents/f4e0a087-c6f4-4f40-bca9-a51cdaf43634/pagecontent"
inthub
:description>The Smashing Pumpkins/Bullet With Butterfly Wings</
inthub
:description>
inthub
:triggerId />
inthub
:offset>00:00:02.000</
inthub
:offset>
inthub
:takeCount>0</
inthub
:takeCount>
inthub
:createdBy>manual</
inthub
:createdBy>
inthub
:infoIntegrationsHub />
inthub
:loaded>1.00</
inthub
:loaded>
inthub
:available>1.00</
inthub
:available>
inthub
:isManuallyEdited>true</
inthub
:isManuallyEdited>
inthub
:duration>00:00:10.000</
inthub
:duration>
inthub
:pageId>6000</
inthub
:pageId>
inthub
:infoPromoServer>[13:40:14]</
inthub
:infoPromoServer>
inthub
:metadata>
inthub
:attribute
name
"some_metadata"
>some data</
inthub
:attribute>
inthub
:metadata>
inthub
:secondaryEvent>
Disallowed Actions
This end-point does not allow POST, and will return a 'HTTP/1.1 405 Method Not Allowed'.
