GET Channel Pool (Version 2.0)
By following the downlink from channel pool under a channel we can retrieve a channel's channel pool.
Syntax
GET /api/channels/[channel]/channel_pool
Request
GET /api/channels/test/channel_pool HTTP/1.1
Response
HTTP/1.1 200 OK
Content-Type: application/vizrt.integrationshubv2+xml; type=channelpool
inthub
:channelPool
xmlns:xsi
"http://www.w3.org/2001/XMLSchema-instance"
xmlns:inthub
"http://www.vizrt.com/integrationshub"
inthub
:name>channel_pool</
inthub
:name>
inthub
:refLink
rel
"self"
type
"application/vizrt.integrationshubv2+xml; type=channelpool"
href
"http://127.0.0.1:9991/api/channels/test/channel_pool"
inthub
:refLink
rel
"events"
type
"application/vizrt.integrationshubv2+xml; type=list"
href
"http://127.0.0.1:9991/api/channels/test/channel_pool/events"
inthub
:description>Channel Pool</
inthub
:description>
inthub
:loaded>0.30</
inthub
:loaded>
inthub
:available>0.50</
inthub
:available>
inthub
:channelPool>
Disallowed Actions
This end-point does not allow POST, PUT or DELETE , and will return a 'HTTP/1.1 405 Method Not Allowed'.
