XML Translator
XML Translator is a command-line tool for transforming a schedule-file in XML (BXF) format to a format Playlist Importer can import. Content is not changed - the data format is only transformed so the Playlist Importer can process it.
Any third-party can define an XSLT (.xst) transformation to an importer-friendly structure, currently:
Ordered collections
Two (2) layers deep only
Using XML Translator
Open a command window (Windows-button+R CMD <enter>) to use the XML translator. If you need admin rights when using the tool, start CMD as Administrator. Next, right-click CMD and select Run as Administrator to start an elevated session. In the following, it is assumed that you have XML translator program in the Windows PATH. If not, you must provide the full path in order to use the tool.
XMLTranslator.exe -SourcePath %path% -DestinationPath %dpath% -SuccessPath %spath% -FailPath %fpath% -TranslationFile %tpath%\XSL.xslt
The example invocation above is on one line. All arguments are required. To get usage instructions, run the program with the help flag (-? or -h or):
XmlTranslator.exe –-help
Program argument definitions:
SourcePath the directory that contains the XML file to translate
DestinationPath a directory in which the translated XML file is created
SuccessPath a directory to which the source XML file is moved when translation succeeds
FailPath a directory to which the source XML file is moved if the translation fails
TranslationFile path to the XSL file defining the transformations
A typical run (the command must be entered on a single line) could be:
XMLTranslator.exe -SourcePath D:\Source -DestinationPath D:\Destination -SuccessPath D:\Success -FailPath D:\Fail -TranslationFile D:\BroadViewXML.xsl
