Channel Deck Configuration and Layout
Settings
Primary event Settings |
Description |
Countdown to start time |
Count down timer for scheduled playout "Start Time" Format: DD:HH:MM:SS |
Start time |
Static time display based on playout "Start Time" Format: Datetime based on System settings eg.
Secondary event Settings |
Description |
Count down timer for scheduled playout "Start Time" Format: HH:MM:SS |
Offset |
Static offset time based on playout secondary event "Offset" |
Calculated start time |
Static time display based on playout "Start Time" + Secondary event "Offset" Format: Datetime based on System settings eg.
Notification of error messages |
Description |
Collapse notification |
Error "pop-up" is by default collapsed and requires a button click to display details |
Pop-up notification |
Error "pop-up" is by default showing and displays details, can be closed by pressing the close button |
Working with Settings
Changing Settings
To update settings
To update settings, press the Menu button at the bottom-right.
Select Settings.
Changing Layout
To Change the view layout
Select Change layout.
