PUT on Playlist in Channel (Version 2.0)
Update a playlist definition.
Name and broadcast date can't be adjusted from it's original value.
Description is automatically set, if left empty.
If any values are set for loaded, available and update, the payload will be accepted but the values will be ignored as they can't be set.
Syntax
PUT /api/channels/[channel]/playlists/[playlist]
Request
PUT /api/channels/test/playlists/continuous HTTP/1.1
Content-Type: application/vizrt.integrationshubv2+xml; type=playlist
inthub
:playlist
xmlns:xsi
"http://www.w3.org/2001/XMLSchema-instance"
xmlns:inthub
"http://www.vizrt.com/integrationshub"
inthub
:name>continuous</
inthub
:name>
inthub
:description>Continuous Playlist1</
inthub
:description>
inthub
:broadcastDate>continuous</
inthub
:broadcastDate>
inthub
:playlist>
Response
HTTP/1.1 200 OK
inthub
:playlist
xmlns:xsi
xmlns:inthub
inthub
:name>continuous</
inthub
:name>
inthub
:refLink
rel
"self"
type
"application/vizrt.integrationshubv2+xml; type=playlist"
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous"
inthub
:refLink
rel
"edit"
type
href
inthub
:refLink
rel
"primaryevents"
type
"application/vizrt.integrationshubv2+xml; type=list"
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents"
inthub
:refLink
rel
"state"
type
"application/vizrt.integrationshubv2+xml; type=playliststate"
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/state"
inthub
:refLink
rel
"refresh"
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/refresh"
inthub
inthub
:description>
inthub
inthub
:broadcastDate>
inthub
:loaded />
inthub
:available />
inthub
:updated>2023-01-25T15:13:10Z</
inthub
:updated>
inthub
:playlist>
