Version 3.9 | Published January 25, 2024 ©
Deploy Agent Modes
The Deploy Agent supports two modes:
Standard Mode: Creates only folders on the destination server which contain files that have to be copied by the task. This mode ensures that the folders on the source and destination servers have the same UUID if possible. I.e. folders outside of the original structure which contain references and/or folder links of files inside the structure have new UUIDs assigned if their original UUIDs are present on the destination server.
Direct Deploy Copy Mode: Also creates only folders on the destination server which contain files that have to be copied by the task. This mode ignores the UUID of folders and makes sure that all folders have the correct name in the structure
Standard Mode Supported Options
The standard mode supports these options:
Options |
Supported Item |
Schedule Options |
Real-time |
Data Mode Options |
Folder based (Only a single folder can be selected per task) |
Real-time Options |
Rebuild original structure |
Time Steered Options |
Copy to target folder only |
User Triggered Options |
Direct Deploy Copy Mode Supported Options
The Direct Deploy Copy Mode (DDC) mode supported these options:
Note: Real-time is not supported in this mode.
Options |
Supported Item |
Schedule Options |
Time steered |
Data Mode Options |
Additional Information on Data Modes
File based: The task is not able to execute if the objects to deploy contain folders
Search criteria based: The task ignores all folders that are contained in the result of the search.
Standard and DDC Supported Options
Data Mode |
Options |
Standard Mode |
DDC Mode |
Real-time |
Time-steered |
User-triggered |
Real-time |
Time-steered |
User-triggered |
Folder based |
Rebuild structure under target folder |
File based |
Search criteria based |
