Viz Licensing Administrator Guide
Version 3.0 | Published September 14, 2023 ©
Microsoft Azure Cloud
To ensure full license availability, back-ups need to be created using blob storage (unmanaged OS disk).
1. Create a VM with unmanaged disks and select the storage account that supports blob.
images/download/attachments/125465988/1.PNG
images/download/attachments/125465988/1_1.PNG
2. In order to view the OS VHD disks of VM, you need the Microsoft Azure Storage Explorer tool. This tool can be installed from https://azure.microsoft.com/en-us/features/storage-explorer/. Follow the on-screen instructions and install the tool on your computer. Open the Microsoft Azure Storage Explorer with Azure subscription. After successful authentication, the storage blob is displayed in Windows Explorer.
images/download/attachments/125465988/2.PNG
3. When VM is ready in Azure, log in to the machine, install the license container and activate it.
images/download/attachments/125465988/3.PNG
4. In the Storage Explorer, right-click on the selected VM and select Make Snapshot. This will create a snapshot of the OS disk with the current information (including the license container).
images/download/attachments/125465988/4.PNG
5. Disconnect the RDP-connection and stop the VM in the Azure portal.
6. In the Storage Explorer, right-click on the original VHD (base blob) and select Break Lease. This will detach the OS disk from the VM, and change the Lease-state to Broken.
images/download/attachments/125465988/6.PNG images/download/attachments/125465988/6_1.PNG
7. Now, copy the snapshot over the base blob by right-clicking the snapshot and select Promote Snapshot and click Yes to overwrite the disk.
images/download/attachments/125465988/7_1.PNG
images/download/attachments/125465988/7.PNG
8. The base blob is overwritten by the snapshot. Attach it to the VM by selecting Acquire Lease in the context menu.
images/download/attachments/125465988/8.PNG
9. The Lease-state changes to Leased and the attached VM information should be displayed.
images/download/attachments/125465988/9.PNG
10. Start the VM in the Azure portal. This VM should use the restored base blob.
