Viz Licensing Administrator Guide
Version 3.0 | Published September 14, 2023 ©
License Options
Supported Setups
Client Type |
Hardware Dongle |
Software/WIBU Container |
License Server |
On-Premise |
Physical local machines |
Virtualized local machines |
Physical license servers |
Virtualized license servers |
Cloud |
Client machines |
License servers |
Note: Whilst technically possible to have a physical license server within the software container, it is strongly recommended to use a physical dongle. See the License Server Issues below. |
Hardware Dongle
These are recommended for on-premise license servers, as they can be attached to a backup server without further restrictions.
When software/WIBU dongle containers are used, a full daily backup including system state is recommended to allow for a smooth restore that includes the current license status.
Please read the following carefully:
Cloud based license servers are not supported.
Using a virtualized license server, requires routing the WIBU dongle (USB device) to the specific VM, and needs to be visible inside the Codemeter software. Vizrt is responsible for providing a functioning WIBU dongle, and does not further support the dongle's use in a VM setup.
Quick Troubleshooting
Software container protection is performed on the hardware elements at validation.
If you change the hardware, the WIBU container validation may fail, making licenses unavailable. -
Where the license server is placed on a VM setup, a common issue will be the dongle not displaying in the CodeMeter. This can be difficult to identify, as incomplete dongle routing may appear at first examination, to be correct.
