Viz Social Deployment Guide
Version 1.0 | Published June 22, 2021 ©
Submission of Individual Posts
Submission via JSON Files
Viz Social is able to accept Posts generated by external sources. Out-of-the-box, this is supported via files formatted in Viz Social’s native POST JSON format.
Syntax by Example
Each series of external Posts must be formatted as an items array of Posts. Please find an example of such an array below:
{ "items": [ { "id": 1, "sticky": true, "author": "Malorie Espinoza", "nickname": "malorieespinoza", "profile_id": 384, "profile_image_url": "https://example.never.no/test/img/profile-01.jpg", "title": "Message #1", "message": "My favourite Pokémon is #291 Ninjask #pokemon #pokemongo ", "timestamp": "1534862969020", "permalink": "https://example.never.no/messages/index.php?ref=eyJpZCI6MSwidWlkIjozODQsIm1pZCI6MjkwLCJpaWQiOjIsInVybCI6NiwidHMiOjE1MzQ4NjI5NjksIm1zIjoiMTUzNDg2Mjk2OTAyMCJ9", "images": [ { "url": "https://example.never.no/test/img/pokemon/291.png" }, { "url": "https://example.never.no/test/img/img-01.jpg" } ], "videos": [ { "url": "https://example.never.no/test/video/small.mp4" } ], "links": [ { "url": "http://www.pokemon.com/no/pokedex/ninjask" } ] }, { "id": "2", "sticky": false, "author": "Iva Carney", "nickname": "ivacarney", "profile_id": 353, "profile_image_url": "https://example.never.no/test/img/profile-02.jpg", "title": "Message #2", "message": "My favourite Pokémon is #701 Hawlucha #pokemon #pokemongo", "timestamp": "1534862969021", "permalink": "https://example.never.no/messages/index.php?ref=eyJpZCI6MiwidWlkIjozNTMsIm1pZCI6NzAwLCJpaWQiOjksInVybCI6MSwidHMiOjE1MzQ4NjI5NjksIm1zIjoiMTUzNDg2Mjk2OTAyMSJ9", "images": [ { "url": "https://example.never.no/test/img/pokemon/701.png" }, { "url": "https://example.never.no/test/img/img-02.jpg" } ], "videos": [], "links": [ { "url": "http://www.pokemon.com/no/pokedex/hawlucha" } ] }, { "id": "3", "sticky": false, "author": "Philomena Stephens", "nickname": "philomenastephens", "profile_id": 685, "profile_image_url": "https://example.never.no/test/img/profile-03.jpg", "title": "Message #3", "message": "My favourite Pokémon is #718 Zygarde #pokemon #pokemongo", "timestamp": "1534862969022", "permalink": "https://example.never.no/messages/index.php?ref=eyJpZCI6MywidWlkIjo2ODUsIm1pZCI6NzE3LCJpaWQiOjcsInVybCI6NywidHMiOjE1MzQ4NjI5NjksIm1zIjoiMTUzNDg2Mjk2OTAyMiJ9", "images": [ { "url": "https://example.never.no/test/img/pokemon/718.png" }, { "url": "https://example.never.no/test/img/img-03.jpg" } ], "videos": [], "links": [ { "url": "http://www.pokemon.com/no/pokedex/zygarde" } ] }, { "id": "4", "sticky": false, "author": "Beckie Cannon", "nickname": "beckiecannon", "profile_id": 325, "profile_image_url": "https://example.never.no/test/img/profile-04.jpg", "title": "Message #4", "message": "My favourite Pokémon is #104 Cubone #pokemon #pokemongo", "timestamp": "1534862969024", "permalink": "https://example.never.no/messages/index.php?ref=eyJpZCI6NCwidWlkIjozMjUsIm1pZCI6MTAzLCJpaWQiOjYsInVybCI6NywidHMiOjE1MzQ4NjI5NjksIm1zIjoiMTUzNDg2Mjk2OTAyNCJ9", "images": [ { "url": "https://example.never.no/test/img/pokemon/104.png" }, { "url": "https://example.never.no/test/img/img-04.jpg" } ], "videos": [], "links": [ { "url": "http://www.pokemon.com/no/pokedex/cubone" } ] }, { "id": "5", "sticky": false, "author": "Janie Goodman", "nickname": "janiegoodman", "profile_id": 651, "profile_image_url": "https://example.never.no/test/img/profile-05.jpg", "title": "Message #5", "message": "My favourite Pokémon is #709 Trevenant #pokemon #pokemongo", "timestamp": "1534862969030", "permalink": "https://example.never.no/messages/index.php?ref=eyJpZCI6MTAsInVpZCI6NjUxLCJtaWQiOjcwOCwiaWlkIjoxLCJ1cmwiOjMsInRzIjoxNTM0ODYyOTY5LCJtcyI6IjE1MzQ4NjI5NjkwMzAifQ%3D%3D", "images": [ { "url": "https://example.never.no/test/img/pokemon/709.png" }, { "url": "https://example.never.no/test/img/img-5.jpg" } ], "videos": [], "links": [ { "url": "http://www.pokemon.com/no/pokedex/trevenant" } ] } ], "paging": { "count": 5, "min_id": 1, "max_id": 5, "next_min_id": 6, "prev_min_id": null, "next_url": "https://example.never.no/messages/index.php?count=5&min_id=6", "prev_url": null }}Semantics
Post Field Definitions
The following table contains the definitions of the POST fields and parameters.
Field |
Description |
Required |
id |
Unique message ID. |
Yes |
sticky |
If set to true, the message is sticky (always shown on top of the posts). |
No |
author |
Full name of the author. |
No |
nickname |
Nickname or alias of the author. |
No |
profile_id |
Profile ID. |
No |
profile_image_url |
URL to profile image / avatar. |
No |
title |
Message title, if applicable. |
No |
message |
Message text. |
No |
timestamp |
Timestamp created. Unix timestamp in milliseconds (other formats can be supported on request). |
No |
permalink |
External link to the posted message. |
No |
images.url |
Array with URLs of attached images. |
No |
videos.url |
Array with URLs of attached videos. |
No |
links.url |
Array with associated links. |
No |
Paging
Paging is supported via the dedicated data structure at the end of the example in Syntax by Example. The request from Viz Social uses the request parameters specified in Request Parameters.
Request Parameters
Parameter |
Description |
Required |
count |
Maximum number of posts per return page. |
Yes |
min_id |
The documents returned should not have an ID lower than min_id. |
No |
Response Parameters
The response is expected to transmit the response parameters specified by the Request Parameters.
Field |
Description |
Required |
count |
Number of posts returned in this page. Might be less than the number that was asked for. |
Yes |
min_id |
Minimal ID returned in this page. |
No |
max_id |
Maximum ID returned in this page. |
No |
next_min_id |
Minimum ID to be used by Viz Social to retrieve the next page. |
Yes |
next_url |
Suggested URL to be used by Viz Social to retrieve the next page. |
Yes |
Example: The response to the query: GET https://code.never.no/messages/index.php?count=10&min_id=11 might be:
{ "items": [ { "id": 11, }, .. { "id": 20 } ], "paging": { "count": 10, "min_id": 11, "max_id": 20, "next_min_id": 21, "next_url": "https://code.never.no/messages/index.php?count=10&min_id=21" }}Business Logic
Please take note of the following business logic when integrating an external source of social Posts:
The examples in Syntax by Example show the widest supported set of fields and parameters. Most fields are optional, see Post Field Definitions.
Post must have a monotonously increasing id.
The first request from Viz Social usually leaves out min_id. It is up to the server to decide where to set the initial cursor. A suggested option is to respond with the most recent count posts (or less of there aren’t that many).
It could be that no new records are available when a request comes in. In that case, the server is expected to respond with a count of 0, without the min_id and max_id.
Dynamics
Files with social posts from external sources must be delivered at a well-defined path. File access, transport and naming conventions are not prescribed. After having been agreed to, they form input to Never.no’s integration services.
Submission in Other Formats
Social posts in alternative JSON formats or even via RSS/Atom feeds or plain XML, can often be supported via customized pre-processing on Viz Social.
Important: Customization options should be discussed with Never.no. Please contact the Never.no support team to discuss options and to come to an optimal solution.
