Pilot DBA Installation
The Pilot DBA is used by Database Administrators (DBAs) in order to install, maintain and upgrade the Viz Pilot database.
Viz Pilot’s Database Administrator (Pilot DBA) tool does not have an installer. The tool can be downloaded from Vizrt’s FTP as a ZIP archive, and is located in the same directory as the Viz Pilot installer.
Pilot DBA and all script files are bundled into a ZIP file. Please unzip all files into one folder, for example, C:\temp\PilotDBA.
Install Pilot DBA
Extract the ZIP archive to a preferred directory.
Create a desktop and/or start menu shortcut.
