Video Codecs Installation
If you are previewing proxy versions of video from Viz One using Viz Engine (Viz Engine installed on your control client machine) you must install video codecs. These are not part of Vizrt’s standard installation.
IMPORTANT! Due to licensing requirements, Vizrt does not provide the codecs required for local preview. Users must obtain and install their own codecs.
Note: Codecs are only required when local preview is done, as in the case above. Playout of high-resolution versions does not require codec installation.
Installation Options
Codecs are available from several suppliers. The list below includes several suggestions:
MainConcept video decoder and splitter
IMPORTANT! On Windows 7 machines, default installation of the LAV filters results in the LAV splitter and the Windows video decoder being used, which can lead to problems. This can be avoided by ensuring that the LAV decoder is selected using the Windows 7 filter tweaker tool. See To set a preferred decoder.
Installing codecs for local preview
The example below sets up support for h.264 playback using the FFDShow MPEG-4 codec package and a Matroska Splitter from Haali.
Note: You must have your own license for clip playback as FFDShow does not come with a decoding license.
Make sure you do not have any other codec packages installed on the machine that interfere with FFDShow or the media splitter.
Download the Matroska Splitter from Haali
Download the Windows 7 DirectShow Filter Tweaker
Download the FFDShow MPEG-4 Video Decoder
Make sure you have a license to use the codec
Make sure you download a 32-bit version of the codec
Uninstall older 64-bit versions of the MPEG-4 codec
Install the Matroska Splitter from Haali
Install the Windows 7 DirectShow Filter Tweaker
Install the FFDShow MPEG-4 codec
After installing the FFDShow codec package make sure that no applications are excluded, especially Viz Engine (there is an inclusion and exclusion list in FFDShow).
Set your MPEG-4 32-bit decoder to FFDShow (see how To set a preferred decoder)
You should now be able to preview video clips from Viz One
Setting a preferred decoder
Run the Windows 7 DirectShow Filter Tweaker
In the dialog box click Preferred decoders
Set your MPEG-4/H.264 *32-bit decoder to ffdshow and click Apply & Close
Click Exit
