Getting Started
Template Wizard is a stand-alone application that can be started from the program menu, a desktop shortcut or from Director if it is installed on the same machine.
Starting Template Wizard
Open the program from the Windows Start Menu (Template Wizard), or the desktop icon.
Specify command line parameters for Template Wizard
Right-click the Template Wizard desktop shortcut, and select Properties.
In the Properties window select the Shortcut tab.
To start multiple instances of Template Wizard add -duplicates to the Target path.
"%ProgramFiles(x86)%\vizrt\Viz Pilot x.y\VizTemplateWizard.exe" -duplicates
Note: When starting a duplicate instance you will most probably receive a socket error. Confirm it and you will be able to run duplicate instances of Template Wizard.
To specify the Media Sequencer to connect to, add -mse <host> to the Target path.
"%ProgramFiles(x86)%\vizrt\Viz Pilot x.y\VizTemplateWizard.exe" -mse <host>
To specify the database to connect to, add -db <connect string> to the Target path.
"%ProgramFiles(x86)%\vizrt\Viz Pilot x.y\VizTemplateWizard.exe" -db <connect string>
To specify the inifile to use, add -inifile <inifile> to the Target path.
"%ProgramFiles(x86)%\vizrt\Viz Pilot x.y\VizTemplateWizard.exe" -inifile <inifile>
Start Template Wizard from Director
Either, select Template Wizard on the Tools menu,
Or, right-click a template in the template list, and select Edit Template on the context menu.
