Display Font
The template and data list font settings for Director are set in the initialization (INI) file ContentPilot.ini; for Viz Pilot News this is done in the registry.
*font: *Sets the font for Director. This is set to MS Sans Serif by default but can be changed.
*ListDisplayFont: *Sets the font for Viz Pilot News. This string value is not set by default, and can therefore be used to override the operating system defaults.
Set the display font for Director
Open the ContentPilot.ini file.
Select the LANGUAGE section and set a new Unicode *font *parameter.
Save the file, and restart Director for the changes to take effect.
Set the display font for Viz Pilot News
Open Registry.
Search for the key:
Windows 32-bit: HKEY_LOCAL_MACHINE\SOFTWARE\\[vizrt]\ActiveX\TemplateFiller
Windows 64-bit: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ [vizrt]\ActiveX\TemplateFiller
Add the string value ListDisplayFont with the desired font name as parameter.
