Viz Multiplay User Guide
Version 3.2 | Published March 07, 2024 ©
Introduction
Viz Multiplay is a powerful tool for controlling studio screen content. The simple interface can be used in the control room or by the presenter in the studio.
  • Send content quickly to multiple screens.
  • Dynamic control from a single interface.
  • Control live, video, graphics and still images.
  • Build playlists and full content editing.
  • Browser based, so it can run on any computer or a tablet, with an easy-to-use interface.
images/download/attachments/105104822/vizmultiplay_media_multiplay.png
System Overview
images/download/attachments/105104822/vizmultiplay_standard_system_mse11.png
  • Viz Multiplay is compatible with graphics from Viz Trio and Viz Pilot. Shows from Viz Trio are available in Viz Multiplay.
  • You are able to access and use templates and elements from Pilot Data Server.
  • Is hosted on a URL on Media Sequencer. Any number of clients can connect to the same Media Sequencer, which provides the scheduling for playout.
  • Uses Viz Engine for playout:
    • The video wall feature allows up to four DisplayPort outputs with UHD resolution from a single GPU in a Viz Engine. With Datapath Fx4 display controllers, the number of outputs can be increased to match numerous screens and panels of different shapes and orientations.
    • Also supports Standard SDI-based playout.
  • Can access media assets stored in Viz One.
  • Can open and control newsroom playlists in a MOS workflow.
Related Documents
See the Vizrt Documentation Center for our related products documentation, including:
  • Viz One
  • Pilot Data Server
  • Graphic Hub
  • Viz Trio
  • Media Sequencer
  • Viz Engine
Feedback
We welcome your feedback and suggestions regarding Vizrt products and this documentation. Please contact your local Vizrt customer support team at http://www.vizrt.com.
Support
