Introduction
The Mosart Remote Control Service (RCS) provides a REST API for controlling Viz Mosart rundowns using REST. This interface in effect duplicates some GPI/O calls (0-4) for rundown operations.
Working with the REST API
Prerequisites/Conditions
The descriptions below of the command assume that RCS and the user work on the same machine and its name is localhost.
The API hosted by RCS and configured to run on port 55167. This port can not be configured.
Employs API key-based authentication where the key needs to be passed in a HTTP header called "X-API-key". See Authentication below.
All routes under "/api/v1/command" are protected.
All commands of this API are accessible only when RCS is running.
Swagger Documentation
The Swagger documentation that describes every command can be found at http://localhost:55167/swagger/.
Command Descriptions
Reload rundown
Start/Continue rundown
Skip Next
Unskip Next
Skip Next Sub Item
Unskip Next Sub Item
Start rundown from top
Enable/disable rehearsal mode
Take a template
Trigger a DirectTake template
Trigger Control Command
Load Rundown
Reload rundown
The Reload endpoint allows you to reload the current rundown by triggering a rundown reload event. The timeline is stopped and the current rundown reloaded from the NRCS cache. No additional parameters.
GET api/v1/command/reload
Start/Continue Rundown
Start or continue the rundown. You can use some optional parameters - see the Swagger documentation.
GET api/v1/command/start-continue
Skip Next
Skip the next item in the rundown.
GET api/v1/command/skip-next
Unskip Next
Unskip a previously skipped item in the rundown.
GET api/v1/command/un-skip-next
Skip Next Sub Item
Skip the next sub item in the rundown.
GET api/v1/command/skip-next-sub-item
Unskip a previously skipped sub item in the rundown.
GET api/v1/command/un-skip-next-sub-item
Start Rundown from Top
Restart the rundown from the first story. No additional parameters.
GET api/v1/command/start-from-top
Enable/disable Rehearsal Mode
Enable/disable/toggle rehearsal mode:
GET api/v1/command/rehearsal-mode?state=true
GET api/v1/command/rehearsal-mode?state=false
Take a Template
Takes the template by its type and variant (name) as well as optionally, which bus (Preview or Program) and, for Preview bus, the insert option (if the template should be inserted in front of or overwrite an existing manual item). If an optional parameter is not used, the defaults are program (for bus) and false for insert.
GET api/v1/command/template?type={template-type}&variant={variant}&bus={preview|program}&insert={true|false}
For example,
GET api/v1/command/template?type=Camera&variant=CAM1
This will cut the Camera template variant CAM1 directly to Program.
GET api/v1/command/template?type=Camera&variant=CAM1&bus=PREVIEW
This will put the Camera template variant CAM1 into Preview, replacing any manual item already in Preview.
GET api/v1/command/template?type=Camera&variant=CAM1&bus=PREVIEW&insert=true
This will put the Camera template variant CAM1 into Preview, inserted in front of the item currently in Preview, not overwriting any manual item in Preview.
Trigger a DirectTake Template
Trigger a given DirectTake template. You must provide the number of the desired template.
GET api/v1/command/directtake?number={number}
Trigger a control command in Mosart.
GET api/v1/command/controlcommand/{command}?params…
Load Rundown
Load/Open a specific rundown in Mosart. This only works with MOS-based rundowns, and you have to provide the ID of the rundown that you want to open. In Vizrt’s Showmaker, you can get this ID by opening a rundown, then copying the ID from the URL.
GET api/v1/command/open-rundown?id={rundown-id}
Authentication
All commands require the special API key as a sign that the action has been authorized. This key should be passed in HTTP header called X-API-key.
Remote Control Dispatcher Service (RCS) configuration file
The RCS configuration file contains a new setting RestApi. It's value can be randomly generated to be robust and sustainable against brute-force attack. Each REST call will compare the passed in header key X-API-key with the value from the RestApi setting first.
%ProgramData%\Mosart Medialab\ConfigurationFiles\RemoteDispatcherServiceConfig.xml
<?xml version="1.0" encoding="UTF-8"?><RemoteServiceConfig> <Properties> ... <item name="RestApiKey" value="test-api-key" />curl -X GET "http://localhost:55167/api/v1/command/reload" -H "accept: */*" -H "X-API-Key: test-api-key"Warning: All the above commands will impact the live show on your Mosart server.
