Viz Arc Script Guide
Version 1.7 | Published November 15, 2022 ©
Action Properties
All Actions in the project can be accessed and modified via scripting. Use the GetAction function to get a reference to the action:
BaseAction GetAction(string actionName)
Note: It's possible for a project to contain multiple actions that have the same name. If that is the case for your project, the first Action created with a name is returned. Make sure to use unique names when accessing actions through scripting.
Every Action type has these generic properties:
Action type |
Description |
string Name |
The title of the action. |
string Description |
By default this is the type of action (for example, "Key", "Chroma", "Image" etc.). When assigned to a TransformationAction and visible on the SET view, this field is used as a tooltip when the mouse hovers over the element. |
int ExecutionDelay |
Expressed in milliseconds, minimum delay is 0 (default), maximum delay is 10000 (10 seconds). |
Every Action type has these generic methods:
void Execute(): Executes the action.
void Preview(): Executes the action on the preview channel.
void QueryState(): Queries the current state of the action from the Editing Engine. For example, if the action is a transformation action, it retrieves the current transformation from the editing engine's scene tree and updates the UI accordingly.
The example below shows how to set the alpha value to 75% of an Alpha Action called AlphaText and execute the action from scripting:
var alphaAction = GetAction("AlphaText");alphaAction.Alpha = 75.0;alphaAction.Execute();
There are specific properties/functions for each action type:
Alpha
Properties:
double Alpha
Chroma
Properties:
ChromaPrecisionContent Precision
double hueAdjust
double saturationAdjust
int edgeBlur
double despillScale
double backingPlateR
double yellowGain
double cyanGain
int denoiseRadius
int denoiseSharpen
double opacityPoint
doube transparencyPoint
double bgEdgeGain
double bgSpillGain
double bgLWBlur
double colorEdgeGain
double colorSpillGain
double colorLightwrapR
double colorLightwrapG
double colorLightwrapB
bool addShadows
double innerShadows
double shadowsGain
bool addHighlights
double innerHighlights
double highlightsGain
double masterLiftR
double masterLiftG
double masterLiftB
double masterGammaR
double masterGammaG
double masterGammaB
double masterGainR
double masterGainG
double masterGainB
double masterSaturation
var action = GetAction("Chroma");// sample for setting some color Precision Keyer settingsaction.Precision.hueAdjust = -1140;action.Precision.saturationAdjust = 2.0;Command
Properties:
string Command
ControlObject
Director
Properties:
string DirectorType
Possible values: START, STOP, CONTINUE, CONTINUE_REVERSE, PLAY_FROM, PLAY_FROM_REVERSE, FROM_TO, GO_TO, PAUSE
Group
This action has no additional public properties.
Properties:
string Image
Value should be a Graphic Hub path that starts with "IMAGE*"
bool IsBuiltin
string Builtin
Possible values: LIVE1, LIVE2, CLIP1, etc.
double PosX
double PosY
double RotX
double RotY
double RotZ
double ScaX
double ScaY
The Image parameter can be assigned to a Graphic Hub path when the string starts with "IMAGE*"; when it starts with "http" it will be assumed to be a web link (or a Media Service link), otherwise it will be interpreted as a local file path, see the samples below:
var imageAction = GetAction("Image");imageAction.Image = "IMAGE*/VizArc/arcLogo";// orimageAction.Image = "http://127.0.0.1:21099/serve/original/AR_03.jpg";// orimageAction.Image = "C:/Users/admin/Desktop/CAKE.jpg";Light
Properties:
string LightType [read only]
Possible values: NONE, SPOTLIGHT, DIRECTIONAL, AREA, POINT
string LightColor
double LightIntensity
double DiffuseIntensity
double SpecularIntensity
double LightRadius
double OuterConeAngle
double InnerConeAngle
int LightLayer
double DirectionalSpread
double RadiosityMultiplier
Key
Properties:
bool KeyEnabled
bool CombineBackground
bool DepthInfoOnly
bool DrawKey
bool DrawRGB
Material
Properties:
string ColorHex [#RRGGBB]
string Diffuse [#RRGGBB]
string Emission [#RRGGBB]
string Specular [#RRGGBB]
string Ambient [#RRGGBB]
double Alpha [0…100]
double Shiniess [0…100]
bool UseSimpleColor
Functions:
SetColorRBG(int r, int g, int b)
MSE
Properties:
string Page
string DirectorType
Possible values: TAKE, CONTINUE, TAKE_OUT
Multizone Chroma Key
Properties:
string ZoneName
double Height
double Altitude
double Luminance
double MinLuminance
double MinGrad
double MaxLuminance
double MaxGrad
double Blend
double U
double V
double UVDiameter
double UVGradient
bool IsFullscreen
bool PickLuma
bool PickChroma
bool PickInViz
NDI
Properties:
int Preset
Value must be between 0 and 99
float Velocity
Value must be between 0 and 1
Omo
Properties:
int ElementIndex
bool ShowUntil
PBR
Properties:
Modes
bool IsPreload
bool IsGHMode
GH Mode
string PhongMaterialAsset
Value should be a Graphic Hub path that starts with "MATERIAL_DEFINITION*"
Values Mode
Material Settings
string ColorTexture
|string ColorTint
bool ColorIsSRGB
string EmissiveTexture
string EmissiveColor
double EmissiveIntensity
string NormalTexture
string RoughnessTexture
double RoughnessFactor
string MetallicTexture
double MetallicFactor
string AmbientOcclusionTexture
string HeightTexture
double HeightDepth
string EnvironmentTexture
double EnvironmentRotation
Texture Settings
double TillingU
double TillingV
double UvAngle
double UvScaleU
double UvScaleV
double UvOffsetU
double UvOffsetV
Phong
Properties:
Modes
bool IsPreload
bool IsGHMode
GH Mode
string PbrMaterialAsset
Values Mode
Material Settings
string ColorTexture
|string ColorTint
bool ColorIsSRGB
string AmbientTexture
string AmbientColor
For example: "#FF00A0"
double AmbientIntensity
string DiffuseTexture
string DiffuseColor
string SpecularTexture
string SpecularColor
double Shininess
bool Lit
Whether the material should be lit
Texture Settings
double UvAngle
double UvScaleU
double UvScaleV
double UvOffsetU
double UvOffsetV
Scene Loader
Properties:
bool UseGUID
string FrontUUID
string MainUUID
string BackUUID
string GfxUUID
string SubSceneUUID
bool FrontClear
bool MainClear
bool BackClear
bool GfxClear
bool SubSceneClear
bool FrontResetStage
bool MainResetStage
bool BackResetStage
bool GfxResetStage
int GfxLayerNumber [0,…,17]
bool SubSceneResetStage
Script
Functions:
dynamic GetParameterValue(string name)
Returns the value of a Script UI element. The name is the name of the UI parameter as specified in the viz script by the RegisterParameter* function.
bool SetParameterValue(string name, dynamic value)
Sets the value for a UI parameter. The name is the name of the UI parameter as specified in the viz script by the RegisterParameter* function. Returns true on success.
// get the script action with the name "scriptA"let action = GetAction("scriptA")// set some parameter valuesaction.SetParameterValue("aDouble", 3.3)action.SetParameterValue("aInteger", 2)action.SetParameterValue("aString", "another string")action.SetParameterValue("aMultiString", "another\\nmultistring")action.SetParameterValue("aBool", false)action.SetParameterValue("aImage", "c:/tmp/test.jpg")// read the parameter valuesConsole.WriteLine("aDouble value is " + action.GetParameterValue("aDouble"))Telemetrics
Properties:
int Program
int Scene
Text
Properties:
string Text
Tracking Hub Command
Properties:
string Command
Transformation
Properties:
double PosX
double PosY
double PosZ
bool PosEnabled
double RotX
double RotY
double RotZ
bool RotEnabled
double ScaX
double ScaY
double ScaZ
bool ScaEnabled
Utah Router
Properties:
int Source
int Desitnation
Unreal Animation
Properties:
string AnimationMode
Possible values: LOAD, CONTINUE, PAUSE
bool IsLooping
double PlayRate
double BlendTime
string SelectedAnimation
Unreal Blueprint
Unreal Dispatcher
Unreal Scene Loader
Unreal Sequencer
Properties:
string DirectorType
Possible values: START, STOP, CONTINUE, START_REVERSE, CONTINUE_REVERSE, PLAY_FROM, PLAY_FROM_REVERSE, GO_TO, PAUSE
int LoopCount
double PlayRate
Unreal Text
Properties:
string Text
double ScaleX
double ScaleY
Vinten
Virtual Studio
Properties:
int SelectedSceneIndex
bool SendPosition
string SetName
double PosX
double PosY
double PosZ
double RotY
Visibility
Properties:
bool Visibility
string VisibilityMode
Possible values: ON, OFF, ONOFF, DUAL_MODE
Viz Camera
Properties:
int SelectedCamera
bool RemoteEnabled
bool IsRemote
bool AngleEnabled
double Angle
bool PosEnabled
double PosX
double PosY
double PosZ
bool DirEnabled
double Pan
double Tilt
double Twist
Viz Clip
Properties:
string ClipName
bool IsLoader
string ControlType
possible values: START, STOP, CONTINUE, PAUSE
string SelectedClipChannel
bool PlayOnLoad
bool HasLoop
bool ShouldQueue
Viz PBR Material
Properties:
bool IsPreLoad
bool IsGHMode
string ColorTexture
string ColorTint
bool ColorIsSRGB
double HeightDepth
double TillingU
double TillingV
double UvAngle
double UvScaleU
double UvScaleV
double UvOffsetU
double UvOffsetV
