Vizrt Asset Management (VAM) is a media asset management platform that runs as a set of containerised services on a Kubernetes cluster. You install it once on a Windows host using the vamctl installer; the installer brings up the cluster, deploys the VAM services and hands you a web UI for ongoing operation.
The installer makes substantial changes to the host and needs Administrator rights throughout. Before you run it on a machine you care about, understand that it:
- Enables and uses Hyper-V, and creates, reconfigures and deletes virtual machines and virtual switches. An install onto a host that already has VAM VMs re-provisions them, which destroys their contents.
- Runs a rootful Podman machine on WSL 2 — used to build the Talos boot images and stage offline bundles, so it is required for every install — and issues
wsl --shutdownwhile configuring it. That stops every WSL distribution on the host, so save any other WSL work first. - Formats disks you assign to cluster storage. The Deployment Configuration step names each drive it will format before you confirm.
- Installs command-line tooling (kubectl, Helm, talosctl, Podman and others) onto the host.
Use a dedicated host for production. Read Prerequisites first.
What Gets Installed
A single VAM installation consists of:
Component | What it is |
Kubernetes cluster | A small Kubernetes cluster (one or more nodes) that hosts VAM. |
VAM core services | The asset-management services (ingest, search, storage backends). |
Configuration Service | Web UI for managing the installation after setup is complete. |
Supporting infrastructure | Object storage, document store, message broker, in-cluster registry and observability (metrics, logs, traces). |
| The installer and lifecycle tool, kept on disk for upgrades. |
You interact with the installation in three ways:
vamctlinstaller (Windows): used for first-time install, cluster lifecycle (add a node, upgrade Kubernetes), backup and upgrade to a new VAM version.- Configuration Service (web UI): day-to-day operation — installing optional packages, changing platform settings, taking backups, viewing cluster health.
- End-user VAM applications: the actual asset management apps your editors and journalists use; these are out of scope for this document.
Installation Modes
The installer offers three workflows from its start screen:
Workflow | When to use |
Online installation | Install host has internet access. Packages are pulled from the Vizrt registry. |
Prepare offline installation | Run on a host that does have internet, to produce a bundle for an air-gapped install. |
Offline installation | Run on the air-gapped target host with the bundle produced above. |
Additional workflows that are not full installations:
Backup / Restore | Take or restore a backup of an existing installation. |
Cluster context | Switch the installer between multiple managed clusters. |
Settings | Change installer-host settings (registry, paths, etc.) |
Cluster Topologies
You can install VAM in one of two topologies:
- Single-node: one machine runs everything. Recommended for evaluation and small productions.
- Multi-node: one or more control-plane nodes plus worker nodes, for redundancy and capacity. Recommended for production.
The installer supports both Hyper-V (the default on Windows) and VMware vSphere for provisioning the nodes. You can also point the installer at an existing Kubernetes cluster instead of letting it create one. See Prerequisites → Deployment target for what each option requires, and the VMware / vSphere deployment guide for the vSphere path.
Where to Go Next
- First-time install: read the Prerequisites, then follow Running the installer.
- VMware vSphere target: see the VMware / vSphere deployment guide.
- Your own Kubernetes cluster: see Existing / native Kubernetes cluster.
- Air-gapped / no internet: see Offline (air-gapped) installation.
- Existing install, day-to-day operation: head to the Configuration Service guide.
- Upgrade an existing install: see Upgrading.
