The Configuration Service is the web-based control panel for a running VAM installation. You use it for everything except installing VAM in the first place — managing packages, changing platform settings, running backups and checking cluster health.
When to Use the Configuration Service vs. the Installer
Task
Use this
First-time install of VAM
vamctl installer
Upgrade VAM to a new version
vamctl installer
Add or remove a cluster node
vamctl installer
Install / upgrade / uninstall a package
Change platform settings (cert, OIDC)
Take or restore a backup
Configuration Service (or installer for full restores)
Check pod / service health
Manage licenses
How to Open It
Browse to https://<your-vam-host>/config (the exact URL was shown on the installer's Finish screen). Sign in with the OIDC identity provider you configured during installation — see Signing in.
You do not need access to the installer host to use the Configuration Service; it runs inside the cluster and is reachable over the network like any other web app.
The Navigation Map
After sign-in, the left navigation has these sections:
Section
What it's for
Packages
Browse, install, configure, upgrade and uninstall VAM packages.
Platform
Authentication (OIDC), certificates (ADCS), networking, storage license, replication, advanced settings and the audit log.
Backup
Run and schedule backups; verify and restore them.
Cluster
Read-only view of the underlying Kubernetes cluster — pods, workloads, services, events.
Data
Browse the platform data store (in development).
Health
On-demand health scan of the whole installation.
Your account menu (the avatar in the top-right) is where you sign out.
The Packages view is the steady-state workspace — most day-to-day operation happens there.
The storage license (AiStor enterprise license) lives under Platform → Storage license, not a separate top-level section.
Core Concept: Packages
Everything VAM installs is a package. The core asset-management services are packages; optional connectors and integrations are packages; sample data is a package. The Configuration Service is shaped around this:
  • The catalog shows packages available to install.
  • The package detail page shows a single installed package: its current version, its configuration, its lifecycle actions (upgrade, reconfigure, uninstall) and its health.
This means that to configure VAM, or to upgrade a feature, you find the relevant package and operate on it. There is no separate settings surface for individual features.
Where to Go Next
